Arm type ATC component?
19 Apr 2016 19:09 #73612
Yes. There is not a great deal of point putting things like this in the base thread. How far can the tool changer move in 1mS?
Also, if the GPIO is via a Mesa sserial card the inputs only change on a 1mS raster too.
Replied by andypugh on topic Arm type ATC component?
Is it a good practice to add this and carousel to servo-thread?
20 Apr 2016 04:34 #73628
by terkaa
Replied by terkaa on topic Arm type ATC component?
Ok. I have been figuring out how to implement step_forward toggle. Is it ok to define step_forward as param rw? So it can be toggled outside code and within code. Or is there some other option?
Tero
Tero
20 Apr 2016 08:42 #73632
Parameters can't be connected to HAL nets, so won't work for a button.
Anything to be connected to a button needs to be a pin. You can use the action of a pin to change a parameter, and you can use 'ordinary' variables too, which have no HAL visibility.
Time to create page: 0.299 seconds
