Halui Problem
06 May 2016 16:24 #74306
by cyrut2
Halui Problem was created by cyrut2
Okay so im just starting to dive into hal world and please excuse my stupidity. I am using a simple parport card to run my machine. I added
net remrun parport.1.pin-10-in => halui.mode.auto halui.program.run
to get an input from pin 10 which im trying to assign to auto cycle
Here is what i get 'halui.mode.auto' does not exist.
What im trying to do.
Im writing a macro to do the following
Since i have no idea how to edit and create the ladder im trying to find a g code work around.
After lets say 10 parts go through a grinder a npn proximity is activating this input. The counter
I was trying to put this input as a cycle start as each piece ran through the following
#1=0
#2=10 (parts after ran)
g43 x0
o1000sub
o1 IF [#1>#2]
#1=#1+1
O1 repeat [#1>#2]
o1 endwhile
#1=10
G91
G01 Z-0.0000035
M3
After 10 parts i want it to run increments of -0.0000035 as it is grinding. So im trying to loop through the program 10 times then run the absolute of -0.0000035.
I hope im making sense its the first actual month into running linux on live parts.
AC
#1=0
g43 x0
o1000sub
o1 IF [#1>#2]
#1=#1+1
O1 repeat [#1>#2]
o1 endwhile
#1=10
G91
G01 Z-0.0000035
M3
AC
- Thank you received: 1369
06 May 2016 17:40 #74311
Replied by Todd Zuercher on topic Halui Problem
Your halui problem may be, that you're missing a line from your config files.
You need to have "HALUI = halui" under the [HAL] section of your ini file.
If you are wanting your switch connected to parport.1.pin-10-in to run your sub program, I think I would connect it to a Halui mdi command in the [HALUI] section of the ini file.
linuxcnc.org/docs/2.6/html/config/ini_co...ml#sub:HALUI-section
In you iniand in you Hal post gui file
In you ini
[HALUI]
MDI_COMMAND = o100 call
#if o100 is what your o sub program is called
net remrun <= parport.1.pin-10-in => halui.mdi-command-00
