Please Help with Error...
- mjohnsonsa
15 May 2016 23:17 #74700
by mjohnsonsa
Please Help with Error... was created by mjohnsonsa
I am trying to use the Gantry Component with the Parallel Port but am having the following error whenever trying to start up LinuxCNC:
HAL: ERROR: function 'gantry.0.read' need FP
addf failed
My .ini and .hal file are attached, I am trying to get this done ASAP so if you can help give guidance I would really appreciate it. I have been trying to piece together a working solution for 3 days now and am getting discouraged...
Matt
addf failed
Matt
15 May 2016 23:23 #74701
Replied by PCW on topic Please Help with Error...
The gantry component functions need to be added to the servo thread, not the base thread
- mjohnsonsa
16 May 2016 00:04 - 16 May 2016 06:22 #74705
by mjohnsonsa
Replied by mjohnsonsa on topic Please Help with Error...
Thank you, can I add just the gantry component to the servo thread while leaving the parport and stepgen in the base-thread or will that cause some kind of synchronization problem? The reason I ask is because I know the base-thread is the preferred thread since it is faster.
Last edit: 16 May 2016 06:22 by mjohnsonsa.
16 May 2016 02:40 - 16 May 2016 02:40 #74712
The gantry component will only run in the servo thread
(and there is no advantage to running it in the base thread)
Last edit: 16 May 2016 02:40 by PCW.
- mjohnsonsa
16 May 2016 02:44 #74714
by mjohnsonsa
My question was supposed to read if I can move just the Gantry Component to the Servo thread and leave the others in the base thread?
16 May 2016 02:49 #74715
Yes
The gantry comp needs floating point so cannot run in the base thread (where floating point is not supported)
18 May 2016 19:41 #74823
by BigJohnT
Replied by BigJohnT on topic Please Help with Error...
I would use the JA14 branch for a gantry, it is now gantry friendly.
JT
JT
Time to create page: 0.127 seconds
