Auto tool change my M6 command
12 Jun 2010 04:15 #3114 by aike
Hello!
I'm new in HAL and want to create auto tools change procedure.
I have arm and turret with 20 tools.
arm and turret driven by servo.
I've fount in Integration Manual some code for my purpose:
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-loopback iocontrol.0.tool-change => iocontrol.0.tool-changed
I undersand that:
the "wire point" tool-number connected in build in point iocontrol.0.tool-prep-number
then created variable "tool-change-loopback" and connected to butild in iocontrol.0.tool-change, wich itself connected to the point
of end procedure iocontrol.0.tool-changed?
All I need to create my own "tool-change-loopback" function and describe it.
Am i right?
Can anybody help me to make auto tool change (M6Tn command) that it works so as in obviosly CNC.
Thx
14 Jun 2010 11:08 - 14 Jun 2010 11:08 #3135 by andypugh
Tool-changing is normally handled in Classic Ladder, see
wiki.linuxcnc.org/emcinfo.pl?ClassicLadderExamples
for examples.
However, you could probably write a specific HAL component for your toolchanger if you prefer to work in C, that makes it easy to work directly with HAL pin values in code.
linuxcnc.org/docs/html/hal_comp.html
Last edit: 14 Jun 2010 11:08 by andypugh.
Time to create page: 0.075 seconds
