Huanyang vfd Plug-in
- LucaPlotter
25 Jul 2016 16:33 #77998
by LucaPlotter
Replied by LucaPlotter on topic Huanyang vfd Plug-in
behold,
below you will find all my configuration files for both " test" suggested by " pommen " and " test2 " suggested by " vre " .
thank you again very much to all
25 Jul 2016 21:23 - 25 Jul 2016 21:50 #78019
by vre
Replied by vre on topic Huanyang vfd Plug-in
I told you when you run stepconf wizard to not check/use any spindle function/pin
1) run stepconf wizard without sellection of any spindle pin (config without spindle) and without pyvcp panel
2) follow the instructions for huanyang AFTER you run stepconf wizard
Last edit: 25 Jul 2016 21:50 by vre.
- LucaPlotter
30 Jul 2016 15:50 #78161
by LucaPlotter
ok i rerun step by step everything you've told me inserting new files you sent me .
but ccomunque error
./custom.hal:7 : waitpid failed hy_vfd spindle- vfd
./custom.hal:7 : hy_vfd exited without becoming ready
I have two questions arise spontaneously , I have to install any special drivers for r485 stick?
The VFD must be attached and turned on when throwing test2 or should function independently ?
but ccomunque error
30 Jul 2016 17:34 #78165
by vre
1)no
2)no
run:
2)no
run:
ls -l /dev/ttyUSB*
- LucaPlotter
01 Aug 2016 17:56 #78246
by LucaPlotter
FANTASTIC !!!!! I tried to restart test2 after inserting my USB and finalmnete the part program !!!!! and also I see the spindle controls !!!!!
Now I just have to try to connect the VFD and see if it really works !!!
thanks a lot to everyone !!!
will let you know soon!
Time to create page: 0.172 seconds
