Problems with feed-override
- Thank you received: 5872
01 Aug 2016 16:11 #78241
Replied by tommylight on topic Problems with feed-override
Ich hab die ganze verstehen, aber ich brauche das noch nicht.
This is with no google trans......stroy-ing !!!
MFG,
Tom
MFG,
Tom
- Pourtofigh
30 Aug 2016 07:09 #79705
by Pourtofigh
Replied by Pourtofigh on topic Problems with motion.feed-override
I am new linuxcnc user, i am going to use motion.adaptive-feed and control by parport.1.pin-10-in for feedback control axis, after many research i figured out by motion.adaptive-feed.
any body can help in this issue.
Regrads
Regrads
02 Sep 2016 19:47 #79927
Replied by andypugh on topic Problems with motion.feed-override
This sounds like it won't work as you describe it.
motion.adaptive-feed is expected to be a fraction between 0 and 1 (or -1 and +1 for the experimental reverse-feed branch)
A parallel port pin is either on or off. Or do you intend to feed a PWM into the parport pin?
Time to create page: 0.168 seconds
