Error loading lcd
31 Jul 2016 17:01 #78194
by newbynobi
Error loading lcd was created by newbynobi
Hallo,
I am trying to get my display working.
It is connected to a 7i76e and a 7i74 to a 7i73.
But that is irrelevant at this state,
I added in my hal file only one line
loadrt lcd fmt_string="LinuxCNC"
nothing else and I got:
usr/bin/rtapi_app exited without becoming ready
insmod for display failed, returned -1
This error does not help much.
I tested with 2.7.5 and master with kernel 4.1.0-0.bpo.1-rt-amd64
(Jessie with machinekit kernel)
dmesg, linuxcnc.debug and text do not contain any helpful information.
is lcd depending on aspecial kernel?
Norbert
Norbert
31 Jul 2016 18:41 #78199
by BigJohnT
Replied by BigJohnT on topic Error loading lcd
Norbert,
It's loadrt lcd fmt_strings="test"
You are missing the "s".
JT
JT
31 Jul 2016 19:08 #78200
by newbynobi
Replied by newbynobi on topic Error loading lcd
Hallo John,
sorry my fault, it was only a typo, I do load as
loadrt lcd fmt_strings="LinuxCNC"
Norbert
Norbert
31 Jul 2016 20:20 #78205
by BigJohnT
Must be something else...
Works for me...
JT
halrun
halcmd: loadrt lcd fmt_strings="LinuxCNC"
halcmd:
Works for me...
JT
01 Aug 2016 00:02 #78213
by phillc54
Replied by phillc54 on topic Error loading lcd
I tried both my machines.
it never became ready...
phill@lcnc:~$ uname -a
Linux lcnc 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 GNU/Linux
phill@lcnc:~$ halrun
halcmd: phill@lcnc:~$
phill@jessie-64:~$ uname -a
Linux jessie-64 4.4.0-trunk-rt-amd64 #1 SMP PREEMPT RT Debian 4.4.1-1~exp1 (2016-02-10) x86_64 GNU/Linux
phill@jessie-64:~$ halrun
Note: Using POSIX realtime
Waiting for component 'lcd' to become ready.....................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
01 Aug 2016 07:24 - 01 Aug 2016 07:32 #78225
by newbynobi
Same here,
lcd does not become ready, so it is a kernel question and may even be related to 64 bit.Who can help?
Norbert
gmoccapy@machinekit:~/linuxcnc-org$ uname -a
Linux machinekit 4.1.0-0.bpo.1-rt-amd64 #1 SMP PREEMPT RT Debian 4.1.3-1~bpo8+1 (2015-08-12) x86_64 GNU/Linux
Norbert
Last edit: 01 Aug 2016 07:32 by newbynobi.
01 Aug 2016 16:06 #78240
by BigJohnT
I should have included what I was running:
I don't run 64-bit anything so I can't test that.
JT
john@mint-shop ~ $ uname -a
Linux mint-shop 3.4-9-rtai-686-pae #1 SMP PREEMPT Debian 3.4.55-4linuxcnc i686 i686 i686 GNU/Linux
john@mint-shop ~ $ halrun
halcmd:
JT
01 Aug 2016 17:08 #78242
by BigJohnT
Looks an issue with the Preempt RT kernel, I get the same "waiting on....." with my Preempt RT 32-bit on LinuxMint.
JT
JT
01 Aug 2016 17:12 #78243
by BigJohnT
Dewey came up with a patch if you want to try it.
JT
JT
01 Aug 2016 19:05 #78250
by newbynobi
Thanks,
I will test the patch tomorrow and inform!
Norbert
Norbert
Time to create page: 0.328 seconds
