Pin 'halui.jog.0.minus'
22 Aug 2016 21:24 #79280
by nicokid
Pin 'halui.jog.0.minus' was created by nicokid
I started to play again with LinuxCNC after a couple of months ago I mistakenly destroyed my configuration (git clone in mi home )
Now I get this error:In effect I have this Pin setting on the first row of my hal file:But as we see from my configuration halui is activated:in effect on the function halpr_find_pin_by_name (hal_lib.c) there is no trace of pin halui.jog.0.minus.
What did I do wrong?
Thanks, Nicola.
Pin 'halui.jog.0.minus' does not exist
net my-jogxminus halui.jog.0.minus <= pyvcp.x-minus
[HAL]
HALUI=halui
HALFILE = stepcraft-840.hal
#HALFILE = custom.hal
POSTGUI_HALFILE = postgui_call_list.hal
[HALUI]
MDI_COMMAND = G54 G10 L20 P1 x0 M100
Thanks, Nicola.
23 Aug 2016 11:20 - 23 Aug 2016 11:21 #79301
Replied by andypugh on topic Pin 'halui.jog.0.minus'
Which version of LinuxCNC?
In Master the pins are now halui.joint.0.minus and halui.axis.X.minus depending on what you want to jog.
Last edit: 23 Aug 2016 11:21 by andypugh.
23 Aug 2016 22:31 #79343
by nicokid
Replied by nicokid on topic Pin 'halui.jog.0.minus'
thanks for your answer
I use the git version. In fact I had suspected this thing but looking on the web I did not find any reference to this change.
I think I need of halui.axis.X.minus, I want to try this: linuxcnc.org/docs/2.4/html/hal_pyvcp_examples.html
So instead of halui.jog-speed should I use halui.axis.jog-speed?
Nicola.
Nicola.
23 Aug 2016 23:03 #79344
The pins are all documented here:
linuxcnc.org/docs/devel/html/man/man1/halui.1.html
But be aware that halui is _not_ realtime. If you are using physical buttons then it is better to use motion pins where possible:
linuxcnc.org/docs/devel/html/man/man9/motion.9.html
The following user(s) said Thank You: nicokid
24 Aug 2016 17:16 #79366
by nicokid
Uhm...I do not see anything useful in motion.
P.S. halui.axis.x.minus must be used with the lowercase x
Nicola.
Nicola.
08 Dec 2018 16:23 #122054
by jbar
Replied by jbar on topic Pin 'halui.jog.0.minus'
The manual page 793/794 shows jog instead of joint. Should that be changed?
ie should a command such as halui.jog.0.plus
be changed to halui.joint.0.plus ??
After reading this thread, I changed from ...jog.. to ...joint... and it solved my problem.
08 Dec 2018 17:38 #122055
Yes, it should be changed to mention both the axis and joint versions of the jog pins.
The offending text is here:
github.com/LinuxCNC/linuxcnc/blob/b948db...rc/gui/halui.txt#L76
And needs to be changed to match the definitive list here:
The manual page 793/794 shows jog instead of joint. Should that be changed?.
Time to create page: 0.129 seconds
