Hal component for a matrix keyboard
16 Oct 2016 16:37 #81691
by gaston48
Hal component for a matrix keyboard was created by gaston48
Hello,
Why in the real-time space, this component, containing 2 imbricated loops, does not work?
But It works in userspace with some usleep .
It is to decode a matrix of keyboard.
Thank you for help.
Thank you for help.
component keyb2 ;
pin out bit lin# [4] ;
pin in bit coltc# [4] ;
pin out bit touch# [16] ;
function _;
license "GPL";
unsigned c = 0 ;
unsigned l = 0 ;
FUNCTION(_)
for (l = 0 ; l < 4 ; l++)
lin(l) = 1 ;
for (c = 0 ; c < 4 ; c++)
if ( coltc(c) ) touch( (l * 4) + c ) = 1;
else touch( (l * 4) + c ) = 0;
lin(l) = 0 ;
component keyb3 ;
option userspace yes ;
license "GPL";
#include <unistd.h>
void user_mainloop(void)
unsigned c = 0 ;
unsigned l = 0 ;
while (1)
FOR_ALL_INSTS()
lin(l) = 1 ;
usleep(1000);
lin(l) = 0 ;
usleep(200);
16 Oct 2016 18:48 - 16 Oct 2016 18:49 #81695
Replied by PCW on topic Hal component for a matrix keyboard
The keyb2 real time component cannot work properly since the loop will run to completion (in nanoseconds) every thread invocation so the pins (as seen by other hal components) will only reflect the values at the end of the loop
For this to work it should advance one step in the loop per thread invocation, which means you need to maintain the state (loop variables) between invocations.
Last edit: 16 Oct 2016 18:49 by PCW.
16 Oct 2016 19:08 #81697
Replied by cmorley on topic Hal component for a matrix keyboard
Note there is already a matrix keyboard decoder in linuxcnc.
One could use it or use it as a starting point.
www.linuxcnc.org/docs/2.7/html/man/man9/matrix_kb.9.html
Chris M
Chris M
18 Oct 2016 09:41 - 18 Oct 2016 09:44 #81763
by gaston48
Replied by gaston48 on topic Hal component for a matrix keyboard
Thank you for your answers,
I imagine the constraints of real time and
I'm amazed by the performance applied to the servo with Mesa.
Andy component also uses loops "for" imbricated but requires
a slow servo thread. ?
A slow servo thread is not compatible with a control loop ?
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...62b5d63242cd;hb=HEAD
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...346e27306ba8;hb=HEAD
My keyboard also includes two gray switches and somme LEDs
component keyb0 ;
pin out bit lin# [12] ;
pin in bit coltc# [8] ;
pin out bit touch# [88] ;
pin out bit colld# [3] ;
pin in bit led# [36] ;
pin out float out0 ; // manivelle
pin out float out1 ; // incrément de déplacement
pin out float out2 ; // override
license "GPL";
#include <unistd.h>
unsigned tab_gray[16] = {0,1,3,2,7,6,4,5,15,14,12,13,8,9,11,10};
float tab_manivelle[16] = {100,10,1,0,0,0,0,0,0,0,0,0,0,0,0,0};
float tab_increment[16] = {0,0,0,1,10,100,1000,10000,1e6,0,0,0,0,0,0,0};
float tab_override [16] = {0,0.02,0.04,0.1,0.2,0.3,0.4,0.5,0.6,0.7,0.8,0.9,1,1.1,1.20,0};
unsigned c = 0 ;
unsigned l = 0 ;
unsigned index_commut1 = 0 ;
unsigned index_commut2 = 0 ;
while (1)
FOR_ALL_INSTS()
for (l = 0 ; l < 12 ; l++)
lin(l) = 1 ;
usleep(1000);
colld(0) = 1;
colld(1) = 1;
colld(2) = 1;
for (c = 0 ; c < 3 ; c++)
if ( led ((l * 3) + c )) { colld(c) = 0 ; }
for (c = 0 ; c < 8 ; c++)
if ( coltc(c) ) {touch( (l * 8) + c ) = 1;
else touch( (l * 8) + c ) = 0;
if ( l == 11) // ligne 12 on lit les commutateurs
// récupération de la position du commutateur 1
index_commut1 = ((unsigned)coltc(0)) + ((unsigned)coltc(1)<<1) + ((unsigned)coltc(2)<<2) + ((unsigned)coltc(3)<<3);
// récupération de la position du commutateur 2
index_commut2 = ((unsigned)coltc(4)) + ((unsigned)coltc(5)<<1) + ((unsigned)coltc(6)<<2) + ((unsigned)coltc(7)<<3);
out0 = tab_manivelle[tab_gray[index_commut1]] ;
out1 = tab_increment[tab_gray[index_commut1]] ;
out2 = tab_override [tab_gray[index_commut2]] ;
lin(l) = 0 ;
usleep(200);
Last edit: 18 Oct 2016 09:44 by gaston48.
05 Aug 2021 15:33 - 05 Aug 2021 15:34 #216987
by nkp
Replied by nkp on topic Hal component for a matrix keyboard
what's the point not_to_use a component matrix_kb?
what do we win?
what do we win?
Last edit: 05 Aug 2021 15:34 by nkp.
Time to create page: 0.123 seconds
