Relation between HAL pins and EtherCAT Slave Information(ESI) .xml file?
30 Nov 2016 21:43 - 30 Nov 2016 21:45 #83509
by jerryCNC
I am trying to write EtherCAT HAL driver for Beckhoff servo drive AX5000:
* I studied the template of Sittner's driver for DELTA Electronics ASDA series:
--- github.com/sittner/linuxcnc-ethercat/blo...er/src/lcec_deasda.h
* And I studied the EtherCAT Slave Informaion(ESI) file for DELTA Electronics ASDA series:
--- see attached .xml file.
I am wondering how Sittner figured out those HAL pins, which are not found in the ESI(.xml) file?
Thanks!
Thanks!
Last edit: 30 Nov 2016 21:45 by jerryCNC.
08 Jan 2017 17:38 #85481
by chimeno
Replied by chimeno on topic Relation between HAL pins and EtherCAT Slave Information(ESI) .xml file?
Hello, I just pulled out an AX5203 driver and I would like to connect to linuxcnc, have you been able to make them work?
Thank you
Thank you
10 Jan 2017 17:48 #85575
by jerryCNC
Replied by jerryCNC on topic Relation between HAL pins and EtherCAT Slave Information(ESI) .xml file?
Hi, I figured out the HAL logic for linuxcnc.
However, the main problem for AX5000 is not from linuxcnc, but from IgH-EtherCAT-master:
* I am stuck at using IgH-EtherCAT-master to control AX5000.
* You can forget about linuxcnc before solving this problem.
By the way, which hardware are you using as EtherCAT master?
The following user(s) said Thank You: chimeno
10 Jan 2017 20:53 #85590
by chimeno
Hi, thanks for the answer, to your question you are referring to what hardware I am using?
10 Jan 2017 23:00 #85595
by jerryCNC
Yes, what real-time OS is running in what hardware?
As you study more, you will find that distributed-clock is a big issue for controlling AX5000 with IgH EtherCAT master.
11 Jan 2017 20:33 #85624
by chimeno
Hi I am currently using linuxcnc 2.7.8 with mesanet 5I20.
I have two servosystems in AX5203 and AX5206, if we can connect them to linuxcnc
Thank you
Thank you
13 Jan 2017 22:20 - 13 Jan 2017 22:20 #85715
by sirop
Replied by sirop on topic Relation between HAL pins and EtherCAT Slave Information(ESI) .xml file?
<CoE SdoInfo="true" PdoAssign="true" PdoConfig="true">
This usually means that you can change the preconfigured set of PDO (entries) with
ethercat sdo commands .
Last edit: 13 Jan 2017 22:20 by sirop. Reason: typo
Time to create page: 0.762 seconds
