Games joypad and write permissions to /etc/udev/rules.d
Version is 2.6.11.
While I'm asking, the instruction tells me to modify my .hal file and my .ini file. Where are these located?
Sorry to bother you with such basic questions.
If you open the editor with sudo privileges then you would be able to. To do this you need to start in a terminal window and type "sudo gedit" or "sudo mousepad"
Alternatively, save the file somewhere in your home folder then move it with another sudo command.
sudo mv ~/99_joypad /etc/udev/rules.d/
The HAL and INI files will be found in your home folder, inside linuxcnc/configs/
- Thank you received: 1369
A few more questions/ comments if I may.
First, although all works fine in LCNC, halcmd still can't find the joystick. I'm looking at hal_input rather than hal_joystick which doesn't exist in my version.
Second, I notice that the current name for my joystick is js1. There is a js0 in there. Does this correspond to a previous insertion, removal cycle of the joystick and if so how do I stop it re- enumerating each time I plug it in? Or doesn't this matter because of the "unique" naming (I almost certainly- hopefully- will never hear of "DragonRise" again)?
Third, the main .hal file warns me that my changes will be overwritten if I run stepconf again. Which I will certainly do because I haven't finalised the step size for the Unimat yet (short story, but I can't easily get at the stepper pulleys to count the teeth). Is there any way of preserving my changes, or does stepconf recognise these as a special case?
- cncnoob1979
- Thank you received: 75
From a post linked below: This creates a rule by vendor and ID. So not what hub its connected to.
I generated a file /etc/udev/rules.d/90-xhc.rules with the following content to get access to USB without root privileges as the guide says
SYSFS{idProduct}=="eb70", SYSFS{idVendor}=="10ce", MODE="666", OWNER="root", GROUP="users"
Link to thread
Link to HB04 Wiki
If the enumerating prevents your from loading or accessing the device then change this to correspond with what you have. That should stop the problem with failures associated with enumerating. If it does not affect you in the naming scheme then I would believe its fine the way it is.
StepConf will overwrite your file again. The best solution is to make a backup of your ini and save your configuration file; however in StepConf you can save your template (configuration) so you can freely edit until your basic configuration (hal & ini) is complete.
Afterwards you will not run StepCong again, everything else will be completed by hand in your ini and hal files.
Hope that helps and does not confuse you further!
