Setting up independent axis
- Thank you received: 1369
19 Dec 2016 13:36 #84410
Replied by Todd Zuercher on topic Setting up independent axis
Yes, the stepgen component has its own velocity and acceleration limits that you can use to control the speed.
see:
linuxcnc.org/docs/html/man/man9/stepgen.9.html
under parameters.
see:
under parameters.
19 Dec 2016 19:59 #84431
I should have mentioned that this approach is equally applicable to both software and Mesa stepgens. The Pico stepgens appear to use velocity-mode, which means that a PID or Simple TP component is needed, but it is still fairly straightforward.
A User M-Code can take two parameters (P and Q) so you could pass both position and velocity requests to the stepgen.
M100 P100 Q200
would call a file called M100, which might contain something like:
In the G-code you would then monitor the output of a near via G-code input pin with the M66 command to pause execution until the move is completed. (or to timeout and handle the error)
Replied by andypugh on topic Setting up independent axis
it would need to be set by a user M-code using halcmd.
M100 P100 Q200
#!/bin/bash
position=$1
velocity=$2
halcmd setp stepgen.4.maxvel $velocity
halcmd setp stepgen.4.position-cmd $position
exit 0
Time to create page: 0.080 seconds
