Machine warning lights (Red, Amber, Green)
- Thank you received: 1369
06 Jan 2017 16:50 - 06 Jan 2017 16:56 #85350
Replied by Todd Zuercher on topic Machine warning lights (Red, Amber, Green)
halui.program.is-running, goes false when the machine is paused (using the pause button or by an M0/M1 in the file).
Regardless, I believe that the hal example I posted would flash the green light anyway (probably on opposite sides of the stepgen pulse though.)
Last edit: 06 Jan 2017 16:56 by Todd Zuercher.
- Thank you received: 5918
06 Jan 2017 16:56 #85351
Did someone mention me???? What horendous deed did i do mow?
Replied by tommylight on topic Machine warning lights (Red, Amber, Green)
Todd, thanks, I would prefer to keep it all in hal. I seem to be doing a Tommy as its 1:30am here so I'll play in the morning. I did try hard along the lines you suggest.
06 Jan 2017 17:19 #85352
One small note, you might want to tie the red light to a not from halui.machine.is-on, rather than to halui.estop.is-activated. That way the red light will turn on for an alarm shut down rather than only for e-stops.)
06 Jan 2017 22:57 #85368
Replied by rodw on topic Machine warning lights (Red, Amber, Green)
Tommy, you can tell I am still a noob because, It was only 1:30 on the morning! Seasoned professionals like you would be posting at 4:30am
Todd, thanks for your hal example. I was able to fold it into the run/step pause/resume example on the forum here and it now works perfect! The green light remains flashing when single stepping which is also how it should be. I've shot a quick video of the lights so when I' get it up on youtube, I'll post a link here. It is very cool so thanks guys.
06 Jan 2017 22:58 #85369
by bevins
That would cause the red light to be on when the machine is off. You could put other alarms in parrallel with the estop contact on the estop rung and label the red light Alarm.
Replied by bevins on topic Machine warning lights (Red, Amber, Green)
06 Jan 2017 23:24 #85372
I did actually try Todds suggestion and it did not work as expected so I reverted to my old code for the red light. There are several signals I've found that show the estop conditon.
06 Jan 2017 23:28 #85373
by bevins
I dont know how to do it in HAL but in classic ladder, just put the extra alarms in parrallel with the estop N/O so any of the alarms will cause the red light to come on.
06 Jan 2017 23:33 #85374
Todd, as I said in my earlier post, you are correct as the light flashes in a pause or single step situation.
Bevins, I have been ignoring Classic Ladder as so far, HAL has done what I want. I think what complicates HAL is that to implement a simple and clear example like Todd posted, there is a bit of work to get it folded in to existing code. Eg, changing and2.0 to and2.4 and setting the logic inputs elsewhere in the code because the pins are alredy in use.
07 Jan 2017 00:23 #85375
Well here is the video of these lights
- racedirector
- Thank you received: 41
07 Jan 2017 00:42 #85377
by racedirector
Replied by racedirector on topic Machine warning lights (Red, Amber, Green)
Ooooh I am liking this as it it similar to what I want to do. However mine differs in the light bit. I am after the ability to flash a light (basically pulsing an output) to signify different machine status. I have a BD679 attached to pin 14 on my BOB that handles the flashing side of it, its the flashing/pulsing the output in linuxcnc that has me stumped.
Time to create page: 0.182 seconds
