halui.max-speed decrease/increase ... never go to right value
19 Jan 2017 16:51 - 07 Apr 2017 13:53 #86168
by bkt
halui.max-speed decrease/increase ... never go to right value was created by bkt
With my custom com I try to modify via modbus max-velocity ... in order to try these I send via modbus the % value of maxvel needed ... I use a qt gui with slider so I can choose step of 10% and send 10 or 20 or 30 or.....
Halui.max-velocity.scale is fixed to 16.2 in hal file ... and my max halui.max-velocity.value is 1620 ..... so 10 step of changing ...
In my custom comp scan halui.max-velocity.value and convet it on actual percentage of max velocity, if my register change ...comparing the new value of the register with the value percentage of halui, if greater ......
if it is less ....
but nothing appens ...
after this I tried to cycle (halui.max-velocity.decrease 1 and than halui.max-velocity.decrease 0) a number of times corresponding to step .... but nothing happens
Miki
halui.max-velocity.increase = 1
if it is less ....
halui.max-velocity.decrease = 1
Miki
Last edit: 07 Apr 2017 13:53 by bkt.
19 Jan 2017 20:39 #86193
Replied by andypugh on topic halui.max-speed ...
Are you sure that
Doesn't change? You might need a halmeter on it to see it change.
The following user(s) said Thank You: bkt
20 Jan 2017 09:05 #86232
by bkt
Replied by bkt on topic halui.max-speed ...
I use show hal configuration and check all pin halui.max-velocity.xxxxx ... i see increase or decrease pin flashing (depends on the command) but .value pin is fixed to 1620 (my real max value....).
I must select other pin ? I try to select:
first test
if change value first halui.max-velocity.direct-value = 1
than halui increase or decrease pin 1 and than 0 (nr. of time depending of increase/decrease value)
than halui.max-velocity.direct-value = 0
second test
if change value these time not use at all halui.max-velocity.direct-value , but only
first test: halui.max-velocity.value go to value 1 and than not change at all .... but sometime is fixed to 1620
second test: halui.max-velocity.value is everytime fixed to 1620
I need to select some other halui.pin??
Giorgio
first test
second test
Giorgio
21 Jan 2017 11:34 #86348
by bkt
using halmeter is the same ...
Regards
Giorgio
Regards
Giorgio
21 Jan 2017 12:00 #86351
It works for me
Unless I am misunderstanding the problem description?
23 Jan 2017 13:01 - 23 Jan 2017 13:03 #86475
by bkt
i try to use pyvcp pushbutton ....
and I see the halui.max-velocity.value goto 59,9 (from 97200) ... so I try these:
same result.
So I try to observe other halui.max-velocity pin .... and halui.max-velocity.count-enable is all time ON .... I use a std hal file as it output from pnnconfig .... and I use external MPG but I use it only in teleop mode .... in joint and automode is disable .... but halui.max-velocity.count-enable is always ON. Is normal?? for disable it I must disconnect joint.selected-count pin??
Regards
Giorgio
net 1 pyvcp.push-one => halui.max-velocity.increase or2.1.in0
net 2 pyvcp.push-two => halui.max-velocity.decrease or2.1.in1
net 3 or2.out => halui.max-velocity.direct-value
same result.
Regards
Giorgio
Last edit: 23 Jan 2017 13:03 by bkt.
23 Jan 2017 13:16 #86476
I am pretty sure that you do not want to use "direct value" at all.
with "direct value" set to zero any change in mpg counts or toggling of increase / decrease will cause the "value" pin to increase or decrease by "scale"
With "direct value" set to 1 the "value" pin will take the actual value of the mpg counts * scale.
You need to leave "direct value" set to zero, and use the "count-enable" pin if you want to disable the MPG.
23 Jan 2017 13:17 - 23 Jan 2017 13:20 #86478
by bkt
sorry ... I correct my post ...
Last edit: 23 Jan 2017 13:20 by bkt.
23 Jan 2017 13:24 - 23 Jan 2017 13:28 #86480
by bkt
But mu count-enable pin is all time set to "1" ... and in these case I not wont to use mpg.
I try to use MPG only in teleop(and these obviusly work fine) .... but in automode I woult to use halui.increase and decrease value without use MPG value at all .... so I think the correct way is these right?:
Giorgio
P.S. the same ....
setp halui.max-velocity.scale 16.2
setp halui.max-velocity.direct-value 0
Giorgio
P.S. the same ....
Last edit: 23 Jan 2017 13:28 by bkt.
23 Jan 2017 18:17 - 23 Jan 2017 18:17 #86493
by bkt
These is the right sotlution??
Tomorrow I test it ... but my halui.max-velocity.count-enable is set to "1" from mi hal file I suppose ....
Regards
Giorgio
net 1 pyvcp.push-one => halui.max-velocity.increase or2.5.in0
net 2 pyvcp.push-two => halui.max-velocity.decrease or2.5.in1
net 3 or2.5.out => halui.max-velocity.count-enable
Regards
Giorgio
Last edit: 23 Jan 2017 18:17 by bkt.
Time to create page: 0.307 seconds
