halui.max-speed decrease/increase ... never go to right value
23 Jan 2017 22:49 #86520
Replied by andypugh on topic halui.max-speed ...
I don't see any reason that you would need the "or2" components.
Do you want to actually prevent the MPG working in some modes?
The following user(s) said Thank You: bkt
24 Jan 2017 10:08 - 24 Jan 2017 10:17 #86543
by bkt
Sorry I not undestand ... so if halui.max-velocity.count-enable is set to 1 MPG not work? (these is not right ... I test it)
Actually MPG can enable and disable via mux4 comp (connected to as jogincrements and set increments to 0 ... so scale go to 0.... so MPG is disable ....
I need to move max-velocity in axis gui using halui.max-velocity.increase/decrease pin ... not need manage manual MPG movement of machine. This pieces of hal file woks fine .... I eneble and disable MPG from external button without problem.
But I'm not able to select different Max Velocity in gui axis with remote slider using halui.max-velocity pin.....
If manually change in axis gui Max Velocity slider I see halui.max-velocity.value change but I'm not able make the same with remote slider ....
Sorry I'm not able to explain me better .....
so for make these I must use only (actually my halui.max-velocity.count-enable is set to 1)
without use any other pin??
In these way only have Max Velocity in gui axis se to 59.9 or to 0 .....
Giorgio
Replied by bkt on topic halui.max-speed ...
net 1 pyvcp.push-one => halui.max-velocity.increase
net 2 pyvcp.push-two => halui.max-velocity.decrease
Giorgio
Last edit: 24 Jan 2017 10:17 by bkt.
24 Jan 2017 10:22 #86544
I think that the increase and decrease buttons should work regardless of "count-enable" and should increase or decrease the "value" by +"scale" or -"scale"
And I am in the same situation. I really don't know what you are trying to do.Sorry I not undestand .
No, quite the opposite. If "count-enable" is zero then the MPG will not work. If it is 1 then it will work... so if halui.max-velocity.count-enable is set to 1 MPG not work? (these is not right ... I test it)
24 Jan 2017 12:05 #86550
by bkt
so if would to increase the halui.max-velocity.value by step of 10 .... I do these:
is right these??
Regards
Giorgio
setp halui.max-velocity.count-enable 0
setp halui.max-velocity.scale 10
is right these??
Regards
Giorgio
06 Apr 2017 17:18 - 06 Apr 2017 17:27 #90975
by bkt
Ok I see my problem ....
if I set:
and use 2 pyvcp button for increase and decrease the axis max-vel I see the value go to 60.0 (from 210000) and then it move of 1 point every pressure of "decrease button" so 59, 58, 57 and so on .....
but my proble now is: Why the valoge goes from 210000 (maximum) to 60?? whitch parameter in ini file make the value show on screen of axis gui??
Seeing axix.py I found:
So it seems the value is bring in a sort of arbitrary way after every update .... if these value is all different I think logically it bring the last one ... is right?? (sorry don't speak python very well)
Giorgio
if I set:
setp halui.max-velocity.scale 0.01
mv = inifile.find("DISPLAY", "MAX_LINEAR_VELOCITY") or inifile.find("TRAJ", "MAX_LINEAR_VELOCITY") or ....
Giorgio
Last edit: 06 Apr 2017 17:27 by bkt.
07 Apr 2017 13:43 - 07 Apr 2017 13:51 #91006
by bkt
work around these issue ... specify:
Actually I work without use MPG. No other command about max-velocity command .... only these 3 row in my hal and custom hal file about max-velocity ....
if use:
and using HalShow I see halui.max-velocity.value pin at 3500 .... but when press halui.max-velocity.decrease .... halui.max-velocity.value go to 1 ..... if use the axis gui slider halui.max-velocity.value return at 3500 in order to my change of slider on scrren ... but if I press a new time halui.max-velocity.decrease the pin halui.max-velocity.value go to 1 a new time ....
there are something tha i control for solve these?
Giorgio
if use:
Giorgio
Last edit: 07 Apr 2017 13:51 by bkt.
Time to create page: 0.093 seconds
