Loadrt motmod and I/O Pins
- Holzwurm56
29 Jan 2017 19:08 - 29 Jan 2017 19:16 #86921
by Holzwurm56
Loadrt motmod and I/O Pins was created by Holzwurm56
Hello,
i need more than 4 outputpins. Can i create more outputpins with the command:
loadrt motmod [num_dio=16] ?
Hans
Hans
Last edit: 29 Jan 2017 19:16 by Holzwurm56.
29 Jan 2017 19:32 - 29 Jan 2017 19:37 #86923
Replied by PCW on topic Loadrt motmod and I/O Pins
Yes, the current LinuxCNC version (2.7.8) supports up to 64 AIO and 64 DIO pins
man motion
for available motmod options
Also the brackets are just to indicate that a parameter is optional so the added token
to the "loadrt motmod" line would just be num_dio=16
man motion
Last edit: 29 Jan 2017 19:37 by PCW.
- Holzwurm56
29 Jan 2017 20:03 #86925
by Holzwurm56
Replied by Holzwurm56 on topic Loadrt motmod and I/O Pins
Hello,
had i to write the complete loadrt motmod syntax or is "loadrt motmod num_dio=16" alone possible?
Its then possible to switch a outputpin on and off with "net motion.digital-out-10 hm2_5i25.0.7i77.0.0.output-10"
and M64 P10 ?
Hans
and M64 P10 ?
Hans
29 Jan 2017 20:07 #86926
Sure but you need a signal name, net commands have the following syntax:
net signal_name pinX pinY pinZ
so something like
net hair_on_fire motion.digital-out-10 hm2_5i25.0.7i77.0.0.output-10
would be the proper syntax
so something like
29 Jan 2017 20:48 #86928
No, you need to add the num_dio=16 token to the existing loadrt motmod line
- Holzwurm56
30 Jan 2017 07:13 #86949
by Holzwurm56
Hello,
in my hal is no motmod but there is a EMCMOD. Is this the same?
Hans
Hans
Time to create page: 0.076 seconds
