MOTMOD and EMCMOD
30 Jan 2017 07:27 #86950 by Holzwurm56
MOTMOD and EMCMOD was created by Holzwurm56
Hello,
in my hal is no motmod but a emcmod. Is this the same?
Hans
30 Jan 2017 15:27 #86974 by PCW
Replied by PCW on topic MOTMOD and EMCMOD
Yes, but if you have emcmot you have a _very_ old version (6 years old ?)
of LinuxCNC and should probably update it
30 Jan 2017 21:12 #87000 by Holzwurm56
Replied by Holzwurm56 on topic MOTMOD and EMCMOD
Hello,
I use 2.7.8 with Wheezy, my hal is created with pncconf.
Hans
30 Jan 2017 21:34 - 30 Jan 2017 21:35 #87004 by PCW
Ahh pncconf uses EMCMOT as a INI file token
just add the num_dio=16 token to the end of the
loadrt [EMCMOT]EMCMOT blah blah blah
line
Last edit: 30 Jan 2017 21:35 by PCW.
The following user(s) said Thank You: my1987toyota
08 Aug 2021 18:47 - 08 Aug 2021 18:48 #217252 by my1987toyota
Replied by my1987toyota on topic MOTMOD and EMCMOD
line
I just found this post . I am trying to get the M64 and M65 P counts above 4  to trigger my PnP feeders. That did it
Last edit: 08 Aug 2021 18:48 by my1987toyota.
Time to create page: 0.186 seconds
