Hal component delay
20 Feb 2017 13:26 #88336
by jensor
Hal component delay was created by jensor
I am wondering how much delay say a "not" component introduce? For example suppose you run a square wave through a "not" and then run its output into an "and2" along with the original would you get any output from the "and2"?
- Thank you received: 1369
20 Feb 2017 14:20 #88343
Replied by Todd Zuercher on topic Hal component delay
It would depend the order things are loaded into hal. It could be anywhere from 0 (undetectable by halscope) to 2 servo thread cycles.
23 Feb 2017 23:32 #88566
It probably depends on whether the NOT is in the realtime thread before or after the AND2.
A NOT connected to itself can be used to make a thread-frequency square-wave.
Replied by andypugh on topic Hal component delay
Time to create page: 0.076 seconds
