Can you change an input pin in a .COMP?
02 Apr 2017 00:42 - 02 Apr 2017 00:44 #90746
Can you change an input pin in a .COMP? was created by rodw
I am writing a simple component that has a GUI screen variable as an input
In a perfect world, I also wanted to change the value using an analog value in GcodeSo, I would like the screen variable updated if a value is set by a gcode M68 command to keep everything in step like this
I get a compiler lvalue required error. So I am assuming that means input pins are read only and cannot be modifed within a component.
Is this the case and is there any workaround.?
pin in float gcode_input = 95 "Gcode analog input set by M68 command";
pin in float target_volts = 95 "The target volts (default 95.0 volts) set in GUI";
target_volts = gcode_input;
Last edit: 02 Apr 2017 00:44 by rodw.
05 Apr 2017 13:21 #90928
Replied by andypugh on topic Can you change an input pin in a .COMP?
You can use an internal value that is set by the higher (or lower) of either of the two inputs.
Or maybe have a handler in the GUI that allows the GUI value to be over-written by an M-code.
05 Apr 2017 21:25 #90949
Andy, thanks, I think the GUI approach would be best. Gmocappy uses glade and I have edited the plasma.glade XML file in the sim by hand.to tidy up a couple of things but I don't really know where to start to add a new GUI handler that overwrites the target voltage. I guess that would get done in plasma.py.
Can you give me an idea on where to start?
Would the first step be to add a screen variable for the M68 value and set the target voltage in the python file to that value?
Replied by rodw on topic Can you change an input pin in a .COMP?
- fsabbatini
- Thank you received: 44
31 Mar 2022 23:12 #238958
by fsabbatini
Replied by fsabbatini on topic Can you change an input pin in a .COMP?
Sorry for responding years later but yes, there is a way,
each input pin you define is just a macro, so first just undefine temporarily, for example:
POS_CMD is an input from simple_tp.comp. I just added feedback to that component so when simple_tp is disabled i want pos_cmd=pos_fb, so what you must do is push the macro in the preprocessor stack, undefine the input pin macro, modify it as dereference access (like if you where in a "normal" c component) and then pop from the stack
#pragma push_macro("remove_pos_cmd")
#undef pos_cmd
*(__comp_inst->pos_cmd) = curr_pos;
#pragma pop_macro("remove_pos_cmd")
best regards
Franco
#undef pos_cmd
best regards
Franco
04 Apr 2022 12:05 #239237
There is also a (kludgy) way to check if a pin is connected and set the value internally if it is not.
sourceforge.net/p/emc/mailman/message/26519176/
Time to create page: 0.150 seconds
