Huanyang VFD speed display vs LinuxCNC speed display
12 Apr 2017 05:08 - 12 Apr 2017 17:08 #91226
by {HD}
Huanyang VFD speed display vs LinuxCNC speed display was created by {HD}
I have my Huanyang VFD connected to LinuxCNC via a 232-485 adapter. I setup my configurations just like in this video: (4:29 is the time in the video where both configuration files are on screen).
I can turn my spindle on and off and adjust the speed via LinuxCNC software but, the displayed speed in software is different than what is displayed on the VFD LCD.
I have tried "loadusr -Wn vfd hy_vfd -n vfd -d /dev/ttyUSB0 -p none -r 9600 -S 24000" but adding the "-S 24000" seems to change the P144 value of the VFD to 2400. However if I start the software then change the value of P144 back to 3000 it works both speed indicators match.
If I set -S 3000 then at software 1000rpm I get hardware 8000rpm.
If I set -S 24000 then at software 1000prm I get hardware 800rpm.
BUT again
If I set -S 24000 then change P144 back to 3000 then I get software 1000rpm hardware 1000rpm.
What do I need to change to get this to work by default I feel like something is just slightly off.
BUT again
Last edit: 12 Apr 2017 17:08 by {HD}.
12 Apr 2017 15:28 - 12 Apr 2017 15:29 #91251
by {HD}
Replied by {HD} on topic Huanyang VFD speed display vs LinuxCNC speed display
This is the source from hy_vfd.c that I found relevant to my situation.
If you plug my #'s into the variables it seems like it should work. If I pass -S 24000 : 24000(rated motor rev) / 400(max freq) * 50 = 3000. But, 2400 is the value that gets pushed to my VFD.
hc_data->parameter = 144; // PD144 Rated Motor Rev (at 50 Hz)
if (*haldata->rated_motor_rev != 0) {
// user passed in motor max speed
// we know motor max freq
// write the VFD's P144 with "motor speed at 50 Hz"
rpm_at_50hz = (*haldata->rated_motor_rev / *haldata->max_freq) * 50.0;
hc_data->function = FUNCTION_WRITE;
hc_data->data = (uint16_t)rpm_at_50hz;
if ((retval = hy_comm(hc_param, hc_data)) != 0) {
goto failed;
hc_data->function = FUNCTION_READ;
goto failed;
rpm_at_50hz = hc_data->ret_data;
*(haldata->rated_motor_rev) = (rpm_at_50hz / 50.0) * *haldata->max_freq;
if (hc_param->debug) {
printf("read_setup: read setup parameters - OK.\n");
Last edit: 12 Apr 2017 15:29 by {HD}.
12 Apr 2017 17:06 #91260
by {HD}
Well after screwing around for 2 days trying to get it to work. I decided to apply updates/upgrades. I was reluctant to do this because it meant I had to make a Ethernet cable to reach my CNC machine.
DON'T BE LAZY! APPLY THE UPDATES! THEY FIX THINGS!
I don't know what the issue was and the CODE I listed in the previous post was the 'updated' code but it now WORKS!
Problem solved.
Problem solved.
The following user(s) said Thank You: whoppa
15 Dec 2019 23:47 #152701
by whoppa
Replied by whoppa on topic Huanyang VFD speed display vs LinuxCNC speed display
Wow I wish a few posts like this were put in a file somewhere for newbies,
Try this first!.. I spent about two weeks off and on trying to sort this issue before stumbling on to this post. Consulted several local experts, tried 3 different RS485 adaptors and many VFD settings, different wiring twisted pair, shielded cable, added grounds etc.Why is this sort post so hard to find.
I was not aware that a five minute update would fix the problem,
I was not even aware my linuxcnc was not the latest 2.7.14 version.
Great program but why is everything so secret squirrel?
Time to create page: 0.070 seconds
