touch-off in joypad
27 Apr 2017 17:56 #92226
by caio
touch-off in joypad was created by caio
hi there,
i need to grab the "touch off" button (in axis gui) on my joypad.
i'm a bit confused, because i can't find any hal pin connected.
how can i do it?
how can i do it?
28 Apr 2017 12:40 #92261
Replied by andypugh on topic touch-off in joypad
I don't think that you can, unfortunately.
What do you want to happen when you press the button? There might be another way to achieve the same result.
28 Apr 2017 13:05 - 28 Apr 2017 13:06 #92265
by caio
Replied by caio on topic touch-off in joypad
thanks for answer.
i would like the same function the touchoff button do: move the zero point of the loaded gcode on the XY plane, based on the tool position, and adapting the gcode position.
i also tried the G10 command in MDI mode, but it seems to move the zero point only. it don't move the tracks position.
after all, it's the same as the Z-probe do.
alternatively, could i grab the the keyboard's END key?
PS: sorry for my poor english
Last edit: 28 Apr 2017 13:06 by caio.
28 Apr 2017 13:23 - 28 Apr 2017 13:23 #92267
The touch-off button allows you to enter an offset, and that would be a more difficult thing to arrange.
If all you need is to set the current position to zero in X and Y then add this to the [HALUI] sectionThen connect the joypad pin to halui.mdi-command-00 in HAL.
You might need to force a reload/refresh of the preview screen. That is a different puzzle, and I can't recall if we found an answer.
MDI_COMMAND = G10 P0 L20 X0 Y0
Last edit: 28 Apr 2017 13:23 by andypugh.
01 May 2017 11:36 #92430
by caio
it works. i was using a wrong gcode.
it doesn't refresh preview, but doesn't matter for now, i can do it manually in axis.
thanks
thanks
Time to create page: 0.069 seconds
