PWM feedback?
14 May 2017 20:19 #93197
by caio
Replied by caio on topic PWM feedback?
@tommylight
yes, i get a clean square wave 50% dc
@PCW
thanks, i'll try to improve the pid.
i'm also not sure about maxoutput (pid and encoder), i set it up 24000, as the max spindle rpms, is that right?
@PCW
20 May 2017 21:00 #93408
Reading PWM is only really possible with hardware timers, something that can accurately measure the pulse width.
LinuxCNC HAL could only poll the input, so the best time-stamp resolution that you could expect would be same as the thread rate, either 1mS or 50µS if you run a base thread.
This that to get a value with useful resolution from measuring the PWM you would need to run a very slow PWM rate.
(example: 5rpm resolution and 5000rpm required using the base thread at 50µS would be a 20Hz PWM.)
Replied by andypugh on topic PWM feedback?
Sounds strange linuxcnc can't read pwm.
Time to create page: 0.182 seconds
