cannot find -lemchal
20 Jun 2017 09:52 - 20 Jun 2017 09:53 #94720
by BigDo
cannot find -lemchal was created by BigDo
Hi guys!
I am trying to compile a hal component for my VFD (Telemecanique | Schneider Electric Altivar 28) but I get an error
gcc -o atv_vfd .o/atv_vfd.o .o/modbus.o -Wl,-rpath,/usr/lib -L/usr/lib -lemchal -lglib-2.0
/usr/bin/ld: cannot find -lemchal
What is the equivalent of -lemchal(emchal) for LinuxCNC?
Last edit: 20 Jun 2017 09:53 by BigDo.
20 Jun 2017 23:04 #94748
Replied by andypugh on topic cannot find -lemchal
You _might_ be able to use halcompile to compile the component, if it is written in C.
It's probably at least worth a try.
This forum post here is using halcompile:
forum.linuxcnc.org/24-hal-components/289...ivar-vfd-modbus-comp
And that ends up usingin the command line.
-llinuxcnchal
The following user(s) said Thank You: BigDo
- christian99x
12 Oct 2017 11:15 #100263
by christian99x
Replied by christian99x on topic cannot find -lemchal
Did you successfully compile the module and is it working? I'm trying to set it up, but only the start(stop command is wokring, not the speed command (spindle always running at lowest speed).
Cheers!
Cheers!
Time to create page: 0.193 seconds
