WXHC-HD04 pendant not working after update to 2.7.9
- deargonaut
26 Jun 2017 16:44 - 26 Jun 2017 17:51 #94995
by deargonaut
WXHC-HD04 pendant not working after update to 2.7.9 was created by deargonaut
Hi all,
This will be my first post here.
I've been using LinuxCNC for almost two years now and I could always find my the answer to any of my questions. But now, unfortunately, I can't find it anywhere.
So as the topic title mentions: I've updated tot LinuxCNC 2.7.9 and now my wireless XHC-HD04 pendant doesn't work anymore.
I really don't have any more info except the following error. When starting the xhc-hd04 cli it works as well when starting linuxcnc with the sim.hb04 config. I've matched the sim config with my ini. But it keeps failing.
Can someone help me?
Big Thanks!
EDIT
I've got some more debugging. When I run the hxc-hb04 CLI and starting up LinuxCNC I get this:I don't know what it means, but there are errors involved
Big Thanks!
Starting LinuxCNC...
Found file(lib): /usr/share/linuxcnc/hallib/xhc-hb04.tcl
Running HAL shutdown script
Killing task linuxcncsvr, PID=15972
xhc-hb04: waiting for XHC-HB04 device
xhc-hb04: found XHC-HB04 device
xhc-hb04: connection lost, cleaning up
[timestamp] [threadID] facility level [function call] <message>
Debug file information:
xhc-hb04.tcl: using std_start_pause_button
missing operator at _@_
in expression "600.0 _@_800.0"
(parsing expression "600.0 800.0")
invoked from within
"expr {600.0 800.0}"
("uplevel" body line 1)
invoked from within
"uplevel [list expr $v]"
(procedure "setp" line 2)
invoked from within
"setp pendant_util.amux$idx-in0 $std_accel"
(procedure "wheel_setup" line 134)
invoked from within
"wheel_setup $::XHC_HB04_CONFIG(jogmode)"
invoked from within
"if { ![namespace exists ::tp] || ([::tp::passnumber] != 0) } {
connect_pins ;# per ini file items: [XHC_HB04_BUTTONS]buttonname=pin
wheel_setup..."
(file "/usr/share/linuxcnc/hallib/xhc-hb04.tcl" line 556)
invoked from within
"source $filename"
invoked from within
"set result [source $filename]"
(file "/usr/bin/haltcl" line 55)
15972
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
[ 0.000000] [00003e92] libusbx: error [do_close] Device handle closed while transfer was still being processed, but the device is still connected as far as we know
[ 0.000019] [00003e92] libusbx: warning [do_close] A cancellation for an in-flight transfer hasn't completed but closing the device handle
EDIT
[213.343543] [000014eb] libusbx: error [submit_bulk_transfer] submiturb failed error -1 errno=16
[213.343563] [000014eb] libusbx: error [submit_control_transfer] submiturb failed error -1 errno=16
[213.343571] [000014eb] libusbx: error [submit_control_transfer] submiturb failed error -1 errno=16
[213.343578] [000014eb] libusbx: error [submit_control_transfer] submiturb failed error -1 errno=16
[213.343585] [000014eb] libusbx: error [submit_control_transfer] submiturb failed error -1 errno=16
[213.343592] [000014eb] libusbx: error [submit_control_transfer] submiturb failed error -1 errno=16
[213.343599] [000014eb] libusbx: error [submit_control_transfer] submiturb failed error -1 errno=16
[213.343607] [000014eb] libusbx: error [op_release_interface] release interface failed, error -1 errno 22
Last edit: 26 Jun 2017 17:51 by deargonaut. Reason: Extra debug info provided
27 Jun 2017 02:34 #95013
by dgarrett
From the above error, my guess is your ini configuration
is defining one or more [AXIS_n]MAX_ACCELERATION items
in more than one place.
For instance settings like these will give the above error:
Replied by dgarrett on topic WXHC-HD04 pendant not working after update to 2.7.9
[AXIS_0]
MAX_ACCELERATION = 600
MAX_ACCELERATION = 800
The following user(s) said Thank You: deargonaut
- deargonaut
27 Jun 2017 08:29 #95027
by deargonaut
Replied by deargonaut on topic WXHC-HD04 pendant not working after update to 2.7.9
Thanks @dgarrett for pointing into the right direction.
I didn't had multiple MAX_ACCELERATION within one axis stanza.
But I had multiple values throughout the file
I've resolved that and now it works like a charm!
[AXIS_0]MAX_ACCELERATION = 600
[AXIS_1]MAX_ACCELERATION = 800
Time to create page: 0.272 seconds
