1 of 3 to output // 7i73 MPG not functioning
14 Sep 2017 20:38 #98971
I think the encoder side is OK but the example also shows you how to set up the axis select with mux4 and by the sound of it you have totally chosen to ignore my suggestion.
If you are not using a binary coded switch as the example expects, you are on your own to work out how to map switch positions to an axis select
Replied by rodw on topic 1 of 3 to output
If I understand Peters message there is no need to have software MPG thus the code from PNCCONF should work.
14 Sep 2017 21:11 #98975
by tecno
Replied by tecno on topic 1 of 3 to output
Sorry not so at all Rod, PCW jumped in and had another opinion, awaiting his reply how he wants to do it as he should know how to.
My hal is a mess from PNCCONF and what is remarkable there is no 7i73 hal MPG examples anywhere.
Was recommended to buy 7i73 for my setup but now I am like fish on dry land.
15 Sep 2017 08:14 - 15 Sep 2017 10:20 #98983
by tecno
As I get no reply how to do it the 7i73 PNCCONF way I did it the linuxcnc.org/docs/html/examples/mpg.html way.
Now to start tinkering of LUT5 to get indicator to flash when MPG is active.
Last edit: 15 Sep 2017 10:20 by tecno.
15 Sep 2017 10:23 #98989
by tecno
Question
How do I net following
net mpg <= hm2_7i76e.0.7i73.0.1.input-03-not when it is FALSE
to
net ?????? => hm2_7i76e.0.7i73.0.1.output-15
to
15 Sep 2017 10:57 #98991
by tecno
# Activate MPG - ON flashing light in frontpanel
net light <= hm2_7i76e.0.7i73.0.1.input-03
net light => hm2_7i76e.0.7i73.0.1.output-15
So now to get the output to flash.
- Thank you received: 1369
15 Sep 2017 14:00 #98997
Replied by Todd Zuercher on topic 1 of 3 to output
You can use siggen to make an output flash (also need an and2).
linuxcnc.org/docs/html/man/man9/siggen.9.htmlIf you already have other and2s in your config, you will need to adjust the and2 count and pin names accordingly.
loadrt siggen count=1
loadrt and2 count=1
addf siggen.0.update servo-thread
addf and2.0 servo-thread
#Set flash frequency here in Hz
setp siggen.0.frequency 1
net light-in <= hm2_7i76e.0.7i73.0.1.input-03 => and2.0.in0
net flash <= siggen.0.clock => and2.0.in1
net light-out <= and2.0.out => hm2_7i76e.0.7i73.0.1.output-15
The following user(s) said Thank You: tecno
15 Sep 2017 14:34 #98998
by tecno
Hi Todd,
Just back from my shop and this is what I have done before your input, all working now as wanted.
As always I am much appreciated for all your kind support and help here.
Now I have to change to GMOCCAPY and install NATIVECAM as I have the basics ironed out.
Cheers
Bengt
Cheers
Bengt
15 Sep 2017 14:43 #98999
Glad to hear things are progressing well for you. Sounds like you are almost out of the weeds.
I do not use Gmoccapy or Nativcam, so I won't be of much help there.
15 Sep 2017 14:46 #99000
by tecno
Slowly but getting forward day by day and learning my ways in the weed
I am sure others will chime in when time comes, I know Norbert will give support if he has time and FernV also.
Have a nice weekend
Bengt
Have a nice weekend
Bengt
Time to create page: 0.165 seconds
