Teco L510 VFD Driver installation
- IronForestKnives
13 Oct 2017 19:00 #100333
by IronForestKnives
Teco L510 VFD Driver installation was created by IronForestKnives
Hello! I'm new to the forum but have used it as a resource for 6 months or so. I have a Teco L510 VFD I'm trying to control via RS-485. I found the driver that someone has so generously created. I've been trying to figure out how to install it for at least a month. After numerous google searches, consulting linuxcnc.org and trying many different things I've finally decided it was time to ask for help! I'm pretty computer literate(code html,css,etc.), but linux is so foreign to me...
From what I gather, in terminal I'm supposed to navigate to the directory that contains the L510_vfd.c file and submakefile, and
"halcompile --install L510_vfd.c" I've done this and a ton of different other things and keep getting errors. Should I be placing the files in a specific directory before compiling? Also, how is the submakefile installed/used? Any help is greatly appreciated.
- IronForestKnives
14 Oct 2017 02:51 #100340
by IronForestKnives
Replied by IronForestKnives on topic Teco L510 VFD Driver installation
Here's the errors when I try to install it. Tried looking up the missing file but didn't find anything related to linuxcnc/debian.
g0704@g0704:~/Desktop$ cd l510_vfd-master
g0704@g0704:~/Desktop/l510_vfd-master$ ls
l510_vfd.c README.md Submakefile
g0704@g0704:~/Desktop/l510_vfd-master$ halcompile --install l510_vfd.c
make KBUILD_EXTRA_SYMBOLS=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc/Module.symvers -C /usr/src/linux-headers-3.4-9-rtai-686-pae SUBDIRS=`pwd` CC=gcc V=0 modules
make[1]: Entering directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
CC [M] /tmp/tmp2JMyA2/l510_vfd.o
/tmp/tmp2JMyA2/l510_vfd.c:29:19: fatal error: stdio.h: No such file or directory
compilation terminated.
make[4]: *** [/tmp/tmp2JMyA2/l510_vfd.o] Error 1
make[3]: *** [_module_/tmp/tmp2JMyA2] Error 2
make[2]: *** [sub-make] Error 2
make[1]: *** [all] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-3.4-9-rtai-686-pae'
make: *** [modules] Error 2
19 Oct 2017 13:55 #100549
Replied by andypugh on topic Teco L510 VFD Driver installation
As a first step try sudo halcompile --install.
It might just be that your user doesn't have access to the referenced file.
Have you managed to use halcompile for anything else?
- IronForestKnives
20 Oct 2017 00:19 #100566
by IronForestKnives
I tried it once before, but tried again so you can see the result.
g0704@g0704:~/Desktop$ sudo halcompile --install l510_vfd.c
[sudo] password for g0704:
CC [M] /tmp/tmpNKgA_5/l510_vfd.o
/tmp/tmpNKgA_5/l510_vfd.c:29:19: fatal error: stdio.h: No such file or directory
make[4]: *** [/tmp/tmpNKgA_5/l510_vfd.o] Error 1
make[3]: *** [_module_/tmp/tmpNKgA_5] Error 2
20 Oct 2017 00:29 #100567
Googling the error message (I do that a lot suggests
sudo apt-get install build-essential
- IronForestKnives
20 Oct 2017 00:37 #100568
by IronForestKnives
Yeah I tried that early on also. The first time I did it installed, but now just says newest version is already installed. Still have the same error. Could the driver be looking for includes in the wrong directory or something like that?
20 Oct 2017 08:45 #100575
It is either looking in the wrong place or the file simply doesn't exist.
stackoverflow.com/questions/19500018/una...ram-in-linux-mint-15
Has a few suggestions.
- IronForestKnives
31 Oct 2017 17:49 #101075
by IronForestKnives
I tried all of their suggestions, no luck though. Thanks, for the suggestions. I'm gonna keep working on it in my spare time, see if I can get it figured out.
Time to create page: 0.126 seconds
