Jog scale
11 Aug 2010 02:51 #3680
by aike
Hi!
I want to create JOG scale switch. For example (using pyvcp)
<radiobutton>
<choices>["1","10","100"]</choices>
<halpin>"jog-scale"</halpin>
</radiobutton>
In HAL the pin pyvcp.jog-scale.1, pyvcp.jog-scale.10 and pyvcp.jog-scale.100 wiil be BIT = TRUE every time I select one of this item.
Then I need to assign the halui.jog-spped to 10, 100 and 1000 according to jog-scale value.
How can I do it?
The halui.jog-speed is FLOAT type, but pyvcp.jog-scale values are BIT type.
Is there any logical condition like if then else in HAL?
<radiobutton>
</radiobutton>
How can I do it?
11 Aug 2010 04:30 #3682
Replied by cmorley on topic Re:Jog scale
feed the jog buttons into a mux component.. mux8 will convert the three bit inputs to user selectable float values
11 Aug 2010 08:40 - 11 Aug 2010 08:41 #3687
by aike
Replied by aike on topic Re:Jog scale
Hi!
Where is the manual about mux8?
Last edit: 11 Aug 2010 08:41 by aike.
11 Aug 2010 09:43 #3689
Replied by andypugh on topic Re:Jog scale
I always use this page, the HAL components are all listed about half way down.
www.linuxcnc.org/docview/html/
specifically mux8 is
www.linuxcnc.org/docview/html//man/man9/mux8.9.html
11 Aug 2010 13:52 #3702
by aike
Here is the HAL code using mux8
The sel0 - sel2 toggles, but out = 0
What is wrong?
loadrt mux8
setp mux8.0.in0 1.00
setp mux8.0.in1 2.00
setp mux8.0.in2 3.00
setp mux8.0.in3 4.00
setp mux8.0.in4 5.00
setp mux8.0.in5 6.00
setp mux8.0.in6 7.00
setp mux8.0.in7 8.00
net scale-1 <= pyvcp.jog-scale.1 => mux8.0.sel0
net scale-10 <= pyvcp.jog-scale.10 => mux8.0.sel1
net scale-100 <= pyvcp.jog-scale.100 => mux8.0.sel2
I'm see in HAL preferences the flashing sel0 - sel2 when i presses the button
But out = 0 every time
What is wrong?
loadrt mux8
11 Aug 2010 13:59 #3703
You need to addf the mux8 to a thread or it won't run. (servo thread is the one to use)
12 Aug 2010 00:23 #3715
by aike
Thank you
Added "addf" all works now.
