How to install halcompile
22 Aug 2020 17:02 #179015
by daidai
How to install halcompile was created by daidai
I installed linuxcnc on my Raspberry Pi 4 and it works fine using mesa 7c81.
It seems that halcompile is not installed, so I am trying to install it, but it does not work.
I found some similar writings so I tried them but it doesn't work.
I have little knowledge about programming, so I don't know if it's difficult to say, but I'd like to make my own hal component.
Please tell me the solution as clearly as possible.
Below is the error I am facing
pi@raspberrypi:~ $ sudo apt-get install linuxcnc-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package linuxcnc-uspace-dev
pi@raspberrypi:~ $
pi@raspberrypi:~ $ cd usr/realtime-3.4-9-rtai-686-pae/
bash: cd: usr/realtime-3.4-9-rtai-686-pae/: No such file or directory
pi@raspberrypi:~ $
pi@raspberrypi:~ $ sudo apt-get install libgnomeprintui2.2-deb
E: Unable to locate package libgnomeprintui2.2-deb
E: Couldn't find any package by glob 'libgnomeprintui2.2-deb'
E: Couldn't find any package by regex 'libgnomeprintui2.2-deb'
pi@raspberrypi:~ $
pi@raspberrypi:~/linuxcnc-dev $
pi@raspberrypi:~ $
pi@raspberrypi:~ $
pi@raspberrypi:~ $
- Thank you received: 5944
22 Aug 2020 20:34 #179027
Replied by tommylight on topic How to install halcompile
What does
uname -a
in a terminal say ?
What version of LinuxCNC, 2.8 or Master ?
uname -a
in a terminal say ?
The following user(s) said Thank You: daidai
22 Aug 2020 23:44 #179048
by daidai
Replied by daidai on topic How to install halcompile
Thank you for your reply
pi@raspberrypi:~/linuxcnc-dev $ uname -a
Linux raspberrypi 5.4.51-v7l+ #1333 SMP Mon Aug 10 16:51:40 BST 2020 armv7l GNU/Linux
LINUXCNC - 2.8.0~pre1
23 Aug 2020 06:24 #179065
When you start LinuxCNC at the top border there is the version of it and a 4 digit number after pre1,
Try to find that same number here something like
linuxcnc-uspace-dev_2.8.0~pre1.XXXX.................._armhf.deb
buildbot.linuxcnc.org/dists/buster/2.8-rtpreempt/binary-armhf/
And use gdebi to install.
This might not work as you are using a non real time kernel with ARMV and this is made for ARMHF architecture.
What Raspberry ?
What Raspberry ?
23 Aug 2020 11:05 - 23 Aug 2020 11:12 #179091
by daidai
What is 4 digit number ?
I can’t find it.
I can’t find it.
Last edit: 23 Aug 2020 11:12 by daidai.
23 Aug 2020 15:42 - 23 Aug 2020 15:44 #179110
Ooops, it seems you have a compiled version from git and that does not show the build number.
But that also means you should be able to install the dev version the same way.
Last edit: 23 Aug 2020 15:44 by tommylight. Reason: more info
24 Aug 2020 15:34 #179252
by daidai
I'm not sure which dev version is correct, but I just tried installing some.
but I can not install linuxcnc-dev.
Which dev version need to install ?
pi@raspberrypi:~/linuxcnc $ sudo gdebi /home/pi/Downloads/linuxcnc-uspace-dev_2.8.0_pre1.6129.gf5b699979_armhf.deb
This package is uninstallable
Dependency is not satisfiable: linuxcnc-uspace (= 1:2.8.0~pre1.6129.gf5b699979)
pi@raspberrypi:/ $ sudo apt-get install linuxcnc-dev
E: Unable to locate package linuxcnc-dev
pi@raspberrypi:/ $
pi@raspberrypi:/ $ sudo apt-get install halcompile
E: Unable to locate package halcompile
pi@raspberrypi:/ $
pi@raspberrypi:/ $
pi@raspberrypi:/ $
29 Aug 2020 07:11 #179919
by daidai
Finally done
It took a very long time due to lack of knowledge.
I can use halcompile .
cd /home/pi/
sudo apt-get install python-serial
sudo dpkg -i linuxcnc-uspace-dev_2.8.0~pre1_armhf.deb
Thank you
cd /home/pi/
Thank you
- dennis.lewis5
11 Jan 2021 04:49 #194845
by dennis.lewis5
Replied by dennis.lewis5 on topic How to install halcompile
I have been trying to install halcompile as well. Pi 4, with Linuxcnc preempt rt 2.8.0 Debian 10 from linuxcnc.org/iso/linuxcnc-2.8.0-pi4.zip
Following the above example fails with: "dpkg: error: cannot access archive 'linuxcnc-uspace-dev_2.8.0~pre1_armhf.deb': No such file or directory"
same problem with sudo dpkg -i linuxcnc-uspace-dev_2.8.0_armhf.deb.
any help would be appreciated.
11 Jan 2021 13:38 #194902
Replied by andypugh on topic How to install halcompile
I would expect halcompile to already be installed.
If not:
sudo apt-get install linuxcnc-uspace-dev
Should download and install it.
If not:
The following user(s) said Thank You: dennis.lewis5, aerocub
Time to create page: 0.165 seconds
