Modbus TCP issue with pokeys57E
27 Oct 2020 16:52 #187443
by Varang1an
Modbus TCP issue with pokeys57E was created by Varang1an
Hi
I have been trying to set up modbus TCP with pokeys57E on linuxcnc 2.8 RT on debian stretch. For some reason I get error which has caused me to pull out my hair:silly: I took an error report from the whole modbus listing in case if someone knows what could be going on. The file happens to be 1.7mb so it won't fit here as attachment so I had to compress it.
I also attached my modbus.ini file so if anyone kind enough can take a look and hint me what I have set wrong or if pokey57e has some issue with modbus let me know.
Thank you in advance
- BeagleBrainz
- User is blocked
- Thank you received: 570
28 Oct 2020 00:49 #187486
by BeagleBrainz
is your error which is in your nyx.hal file @ or around line 125. After you clear this error you may have others pop up, so it's just a case of either closely reviewing your hal files or fixing one error at a time.
Replied by BeagleBrainz on topic Modbus TCP issue with pokeys57E
Debug file information:
Note: Using POSIX realtime
./nyx.hal:125: Pin 'modbus.xplus' does not exist
4823
Stopping realtime threads
Unloading hal components
28 Oct 2020 05:24 #187511
by rootboy
Replied by rootboy on topic Modbus TCP issue with pokeys57E
You've got:
[modbus.xplus.num_errors]
[modbus.xplus.00]
created already.
Your error is:
"./nyx.hal:125: Pin 'modbus.xplus' does not exist"
Do you want to (or can you?) create a pin that is the root of existing ones?
Otherwise, I'm very familiar with this particular error message. Not all that proficient in fixing them yet however...
Can you post your nyx.hal file?
[modbus.xplus.00]
created already.
Your error is:
28 Oct 2020 07:12 #187519
by Varang1an
Replied by Varang1an on topic Modbus TCP issue with pokeys57E
Ok got forward on this, I had to change "modbus.xplus" to "modbus.xplus.00" and it seems to not complain anymore modbus pins, now however it complains the pin which it is attached in hal "halui.jog.0.plus"
"net jog_x_plus <= modbus.xplus.00 => halui.jog.0.plus
dunno why it can't find the halui pin as I have also halui set in ini file
28 Oct 2020 07:18 #187521
Replied by Aciera on topic Modbus TCP issue with pokeys57E
Can you post your INI and HAL files?
28 Oct 2020 07:24 #187522
by Varang1an
Sorry, I found reason for this... I used hal documentation 2.8 : linuxcnc.org/docs/2.8/html/config/core-components.html
and when I tried instead commands from devel:
linuxcnc.org/docs/devel/html/man/man1/halui.1.html
it works. Dunno how it is possible as I have 2.8. It seems the documentation is not that great on linuxcnc at some parts. I used now "halui.axis.x.plus" and it was accepted
28 Oct 2020 08:00 #187524
Indeed, there is still a reference in the 2.8 docs to halui.jog:
linuxcnc.org/docs/2.8/pdf/LinuxCNC_Documentation.pdf
despite the fact that the halui.jog have been replaced in 2.8:
linuxcnc.org/docs/2.8/html/getting-start...dating-linuxcnc.html
Could somebody fix that?
- BeagleBrainz
- User is blocked
28 Oct 2020 08:02 #187525
by BeagleBrainz
Did you read the 2.8 docs ?
linuxcnc.org/docs/2.8/html/man/man1/halui.1.html
linuxcnc.org/docs/2.8/html/gui/halui.html
28 Oct 2020 08:07 - 28 Oct 2020 08:13 #187526
@Beagle
It's fine there
but it's wrong here
and here:
also here (as I presume this is the doc meant for the current stable release):
linuxcnc.org/docs/html/gui/halui.html
It's fine there
but it's wrong here
and here:
Last edit: 28 Oct 2020 08:13 by Aciera.
- BeagleBrainz
- User is blocked
28 Oct 2020 08:25 #187527
by BeagleBrainz
Another I'd like to add, and this is a situation that has manifested itself a bit lately, is that we've had users having errors and contributing the errors to a part of Linuxcnc. Now if these user had of read the error file, which gives a very clear reason to what the error is, a lot of time could have been saved.
What has frustrated me more, to a point where I gave up offering help, is that some users wont even bother to look or start multiple threads. Even after they have had be shown how to find the error.
Ok rant over....and yes I understand the OP is new.
Ok now would it be easier if the Debug stanza was at the top of the error report ?
Time to create page: 0.227 seconds
