xhc-whb04b-6 and or2 problem with pin
16 Jun 2021 08:50 #212186 by szatri
Hello, I have mpg and additional virtual buttons in axis, I want to combine the functions of the buttons on mpg and on the screen into one function of calling the program
I have these pins / commands:
pyvcp_options.hal:
loadrt or2 count=1
addf or2.0 servo-thread
net or2.0.in0 pdnt.macro.1
net or2.0.in1 halui.mdi-command-01
net pyvcp.safe-z or2.0.out
net remote-safe-z or2.0.out <= pyvcp.safe-z
xhc-whb04b-6.hal:
net pdnt.macro.1                        whb.button.macro-1                 halui.mdi-command-01
file hal:
[HAL]
HALFILE = ploter.hal
HALFILE = custom.hal
HALFILE = xhc-whb04b-6.hal
HALUI = halui
POSTGUI_HALFILE = postgui_call_list.hal
[HALUI]
MDI_COMMAND = O<touch-probe> call
MDI_COMMAND = O<safe-z> call
MDI_COMMAND = O<tool-change> call
MDI_COMMAND = O<parking> call
MDI_COMMAND = O<wrzec> call
##MPG
MDI_COMMAND=(debug,00)
MDI_COMMAND=(debug,macro1)
MDI_COMMAND=(debug,macro2)
MDI_COMMAND=(debug,macro3)
MDI_COMMAND=(debug,macro4)
MDI_COMMAND=G1 G53 X0 Y0 Z0 F4000
MDI_COMMAND=(debug,macro6)
MDI_COMMAND=G1 X0 Y0 Z0 F4000
MDI_COMMAND=(debug,macro8)
MDI_COMMAND=(debug,macro9)
MDI_COMMAND=(debug,macro10)
MDI_COMMAND=(debug,macro11)
MDI_COMMAND=(debug,macro12)
MDI_COMMAND=(debug,macro13)
MDI_COMMAND=(debug,macro14)
MDI_COMMAND=(debug,macro15)
MDI_COMMAND=(debug,macro16)
MDI_COMMAND=G1 G53 Z0 F4000
MDI_COMMAND=(debug,macro17)
MDI_COMMAND=(debug,macro18)
MDI_COMMAND=(debug,macro19)
##MPG
file safe-z.ngc
o<safe-z> sub
M5 M9
G49
G90
G53 G0 Z0
o<safe-z> endsub
m2
file custom_panel.xml
<button>
    <halpin>"safe-z"</halpin>
    <relief>RIDGE</relief>
    <text>"Zetka do gĂłry"</text>
    <bd>1</bd>
    <pady>5</pady>
    <padx>0</padx>
    <font>("Helvetica",12)</font>
    <bg>"#870121"</bg>
    <fg>"#e3e7e6"</fg>
  </button>
file custom.hal is empty
file postgui_call_list.hal:
source pyvcp_options.hal
source custom_postgui.hal
The current configuration shows this error:
pyvcp_options.hal:14: Pin 'pdnt.macro.1' does not exist
These are snippets from the configuration but I only need ordering examples for the net and or2 connections.
16 Jun 2021 10:34 - 16 Jun 2021 10:35 #212190 by alkabal
I think your hal link are not correct
you need to change :
xhc-whb04b-6.hal:
net pdnt.macro.1                        whb.button.macro-1                 #halui.mdi-command-01
and add to your postgui hal
net pdnt.macro.1  => or2.0.in0
net mdi_or2_in1   <= pyvcp.safe-z
net mdi_or2_in1   => or2.0.in1
net mdi-or2_out   => halui.mdi-command-01
Last edit: 16 Jun 2021 10:35 by alkabal.
16 Jun 2021 11:29 #212191 by szatri
Hello, does what I have marked on the screen are mutually exclusive?
I corrected 4 commands, but still the problem:
loadrt or2 count=4
addf or2.1 servo-thread
addf or2.2 servo-thread
addf or2.3 servo-thread
net mdi_or2.0.in1   <= pyvcp.safe-z
net mdi_or2.0.in1   => or2.0.in1
net mdi-or2.0.out   => halui.mdi-command-01
net pdnt.macro.2  => or2.1.in0
net mdi_or2.1.in1   <= pyvcp.tool-change
net mdi_or2.1.in1   => or2.1.in1
net mdi-or2.1.out   => halui.mdi-command-02
net pdnt.macro.3  => or2.2.in0
net mdi_or2.2.in1   <= pyvcp.parking
net mdi_or2.2.in1   => or2.2.in1
net mdi-or2.2.out   => halui.mdi-command-03
net pdnt.macro.4  => or2.3.in0
net mdi_or2.3.in1   <= pyvcp.wrzec
net mdi_or2.3.in1   => or2.3.in1
net mdi-or2.3.out   => halui.mdi-command-04
net remote-touch-probe halui.mdi-command-00 <= pyvcp.touch-probe
net remote-tool-change or2.1.out <= pyvcp.tool-change
net remote-parking or2.2.out <= pyvcp.parking
net remote-wrzec or2.3.out <= pyvcp.wrzec
gives the following error
pyvcp_options.hal:40: Pin 'pyvcp.safe-z' was already linked to signal 'mdi_or2.0.in1'
Only when # it starts, but the buttons do not work:
#net remote-safe-z or2.0.out <= pyvcp.safe-z
#net remote-tool-change or2.1.out <= pyvcp.tool-change
#net remote-parking or2.2.out <= pyvcp.parking
#net remote-wrzec or2.3.out <= pyvcp.wrzec
16 Jun 2021 14:09 - 17 Jun 2021 08:38 #212203 by alkabal
loadrt or2 count=4
net mdi_or2.0.out   <= or2.0.out
net mdi_or2.0.out   => halui.mdi-command-01
net mdi_or2.1.out   <= or2.1.out
net mdi_or2.1.out   => halui.mdi-command-02
net mdi_or2.2.out   <= or2.2.out
net mdi_or2.2.out   => halui.mdi-command-03
net mdi_or2.3.out   <= or2.3.out
net mdi_or2.3.out   => halui.mdi-command-04
Try that i appologize they are a typo error and missed to connect the output signal to mdi in the first attempt
Last edit: 17 Jun 2021 08:38 by alkabal.
17 Jun 2021 08:15 - 17 Jun 2021 08:18 #212262 by szatri
loadrt or2 count=4
net remote-safe-z halui.mdi-command-01 <= pyvcp.safe-z
net remote-tool-change halui.mdi-command-02 <= pyvcp.tool-change
net remote-parking halui.mdi-command-03 <= pyvcp.parking
net remote-wrzec halui.mdi-command-04 <= pyvcp.wrzec
xhc-whb04b-6.hal:
# Connect macro buttons to mdi commands
net pdnt.macro.2                        whb.button.macro-2                 halui.mdi-command-02
net pdnt.macro.3                        whb.button.macro-3		   halui.mdi-command-03
net pdnt.macro.4                        whb.button.macro-4                 halui.mdi-command-04
pyvcp_options.hal:19: Pin 'halui.mdi-command-01' was already linked to signal 'pdnt.macro.1'
Last edit: 17 Jun 2021 08:18 by szatri.
17 Jun 2021 08:33 - 17 Jun 2021 08:36 #212263 by alkabal
your code Edited
loadrt or2 count=4
xhc-whb04b-6.hal:
net pdnt.macro.2                        whb.button.macro-2                 #halui.mdi-command-02
net pdnt.macro.3                        whb.button.macro-3		   #halui.mdi-command-03
net pdnt.macro.4                        whb.button.macro-4                 #halui.mdi-command-04
Last edit: 17 Jun 2021 08:36 by alkabal.
17 Jun 2021 09:26 #212265 by szatri
Thanks a lot, I would never have done it myself.
I have a question if there is any topic about using / calibrating this mpg, because the right switch in manual mode does not change the feed pitch (by a given distance) only the general OVERRIDE (first bar in the axis)
17 Jun 2021 09:55 #212266 by alkabal
Well i'm unsure if i really answear to your question.
the right switch as i know is depending on the selected mode :
at startup is mode Mpg used for feedoverride
you can swap to mode Contiunous or Step using the corresponding button
using lead position you can change spindle override
after go back from position lead you get again Mpg mode for feedoverride
18 Jun 2021 06:41 #212314 by szatri
Hello, which button is it? is it on mpg?
18 Jun 2021 12:22 #212322 by alkabal
yes on both side from mpg wheel
Time to create page: 0.236 seconds
