Realtime serial port HAL?
12 Mar 2011 20:10 #7757
by sam0737
Realtime serial port HAL? was created by sam0737
I would like to create a realtime hal component that call work with serial port. (Ya much like what parport does...)
Don't worry abou telling me the speed of serial port...I am not controlling XYZ-bot over it, but instead I am running a extruder on it. 200 calls/sec is good enough. In fact, I am building a repstrap, and I have a python userspace hal component working, but the jitter is - bad, that's why I want to convert it to realtime component.
The issue is - how could I access the serial port hardware? AFAIK it's supported in RTAI but I have no idea how to load the module, and which header file to reference, etc. Pointers are very much appreciated!
12 Mar 2011 20:55 #7758
Replied by andypugh on topic Re:Realtime serial port HAL?
There is already a HAL module to access the serial port, but it does it on a raw pin basis
www.linuxcnc.org/docview/html/man/man9/serport.9.html
However, you might be able to modify the code to do what you want.
The source file is src/hal/drivers/serport.comp and it is written in the "comp" preprocessing language:
linuxcnc.org/docs/html/hal_comp.html
13 Mar 2011 01:12 #7771
by sam0737
Replied by sam0737 on topic Re:Realtime serial port HAL?
Wow. Looks like serport comp is flipping the register of 8250 and 16550 type serial port...
However, I am using USB serial port...Just wonder if I can get a byte stream interface out of it...
13 Mar 2011 09:44 #7776
sam0737 wrote:
Possibly, but not in Realtime. The problem is not the USB-to-Serial but the actual USB protocol itself. USB is (currently) not usable with realtime.
Somebody tried to fix this and wrote a realtime USB driver for RTAI.
www.rtai.org/RTAICONTRIB/
But it doesn't currently work with the newer kernels (if it ever worked, I have my doubts)
Time to create page: 0.065 seconds
