installed emc2, lathe application, X axis rough
- mkdutchman
I installed emc2 on a Pentium 4 desktop, lathe is setup with 2 step/dir controllers for X and Z (Geckodrives) with a mesa 5i20 and daughter board, I used pncconf to set it up as stepconf didn't seem to support the hardware stepgen
trying to run it triggers the x axis to slowly turn, very rough and jerkily and the Z not at all. Once it starts I can't stop it until the PC is restarted.
I think I need to hand edit the hal file, but oh dear me, where to start? I am very familiar with linux but have never used emc2 before. (But look forward to doing so)
I read through the integrators manual, the hal user manual, and the emc2 user manual, I think the fog is slowly starting to clear now.
1. => Is the hardware mesa stepgen treated just like the software stepgen in the hal file? Same pin out and pin in?
2. => Is there a list somewhere of all available hal components complete with pin outs and pin ins and attributes? Searching and googling turns up only inconclusive results. I want to add some more stuff to this thing in the future and figure I might as well learn the nuts and bolts now.
- Thank you received: 5018
That's odd. Are you sure that you have the correct firmware loaded, and the daughter board connected on the correct header?trying to run it triggers the x axis to slowly turn, very rough and jerkily and the Z not at all. Once it starts I can't stop it until the PC is restarted.
(I don't know about the 5i20, but on the 5i23 the headers are numbered 2,3,and4 not 1,2,3. )
Which firmware is being loaded, and which daughter board are you using.
You should still be within the bounds of what pncconf is meant for, I would check that first.I think I need to hand edit the hal file, but oh dear me, where to start? I am very familiar with linux but have never used emc2 before. (But look forward to doing so)
Yes, they are designed to look the same. (but with different names)1. => Is the hardware mesa stepgen treated just like the software stepgen in the hal file? Same pin out and pin in?
Have a look about half way down this page:2. => Is there a list somewhere of all available hal components complete with pin outs and pin ins and attributes?
www.linuxcnc.org/docview/html/ "Realtime Components and Kernel Modules"
You will find
www.linuxcnc.org/docview/html/man/man9/hostmot2.9.html
Especially interesting. Skim past the Synopsis and straight to "config modparam" for the individual function modules.
Also worth reading
linuxcnc.org/docs/html/hal_basic_hal.html
- mkdutchman
Those links are precisely what I was looking for.......
I'll let you know how it turns out
- Thank you received: 5306
- Thank you received: 2167
What version of EMC are you using?
I have some parker drives that go crazy if power is applied before EMC is loaded but then are fine.
I of course should add a relay so they never power up till EMC is ready.....
- mkdutchman
I still haven't gotten the Z axis to move at all, I must recheck the hardware, I guess
The X axis motor turns in one direction and one direction only.......not sure what's going on there
FWIW I'm using the SVST8_4 firmware in the Mesa 5i20, is there another one I should be using?
Thanks for your time and effort, you guys are a big help
- BigJohnT
- Thank you received: 1177
How to set the pins.
www.linuxcnc.org/docview/html/drivers_hostmot2.html#r1_13
You might have to put that in your custom.hal file
the line to add looks like this:
setp hm2_5i20.0.gpio.048.is_opendrain true
setp hm2_5i20.0.gpio.049.is_opendrain true
this sets both the step and direction pin to open drain for one stepgen.
of course the number 048 (and 049) must correspond to the gpio that represents the step gen.
the formula is : number = pinnum+(connector count*24)
pinnumber is 0-23 (note that pncconf's pin numbers on the mesa page is the connectors's electrical pinout - not what you need)
connector count for the 5i20 is 0,1,2 corresponding to connectors 2,3,4 respectably
so for the svst8_4:
step gen 0 on connector 4 ( which corresponds to 2 see above)
step is pin 0
0 + (2 X 24) = 48
direction is pin 1
1 + (2 X 24) = 49
since that is a little hard to follow another way is to use pncconf to select a gpio signal on a pin close to a stepgen
then you can look at that gpio number and add or subtract the number of positions away from the stepgen.
for the SVST8_4 here are the numbers:
stepgen 0 gpio number 048 and 049
stepgen 1 gpio number 054 and 055
stepgen 2 gpio number 060 and 061
stepgen 3 gpio number 066 and 067
hope that helps but If you are talking about movement that happens before EMC is started then I doubt it.
What you need in that case is either a relay to disconnect power to the drivers or if the drivers have an enable connect the signal amplifier enable to them.
This way there is no movement until EMC is ready to control it.
- mkdutchman
Now, next problem
I'm not seeing the signals output on the geckodrives, I'm not sure why. Taking an oscilloscope and checking shows no pulses output when jogging. I doublechecked the pinout on the drive, that seems to be in order. The strange part is that when inverting the motor signal in the pncconf test/tune window it slowly drives the axis, but only one way.
FWIW, I have my pncconf generated hal file below (without the custom additions)
# Generated by PNCconf at Tue Apr 12 07:54:44 2011
# overwritten when you run PNCconf again
loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hostmot2
loadrt hm2_pci config="firmware=hm2/5i20/SVST8_4.BIT num_encoders=0 num_pwmgens=0 num_stepgens=2"
setp hm2_5i20.0.watchdog.timeout_ns 10000000
loadrt near
addf hm2_5i20.0.read servo-thread
addf near.0 servo-thread
addf hm2_5i20.0.write servo-thread
addf hm2_5i20.0.pet_watchdog servo-thread
# external output signals
# external input signals
# --- ALL-HOME ---
net all-home <= hm2_5i20.0.gpio.050.in
# AXIS X
# Step Gen signals/setup
setp hm2_5i20.0.stepgen.00.dirsetup [AXIS_0]DIRSETUP
setp hm2_5i20.0.stepgen.00.dirhold [AXIS_0]DIRHOLD
setp hm2_5i20.0.stepgen.00.steplen [AXIS_0]STEPLEN
setp hm2_5i20.0.stepgen.00.stepspace [AXIS_0]STEPSPACE
setp hm2_5i20.0.stepgen.00.position-scale [AXIS_0]SCALE
setp hm2_5i20.0.stepgen.00.maxaccel 0
setp hm2_5i20.0.stepgen.00.maxvel 0
setp hm2_5i20.0.stepgen.00.step_type 0
net xpos-fb axis.0.motor-pos-fb <= hm2_5i20.0.stepgen.00.position-fb
net xpos-cmd axis.0.motor-pos-cmd => hm2_5i20.0.stepgen.00.position-cmd
net xenable axis.0.amp-enable-out => hm2_5i20.0.stepgen.00.enable
# ---setup home / limit switch signals---
net all-home => axis.0.home-sw-in
net x-neg-limit => axis.0.neg-lim-sw-in
net x-pos-limit => axis.0.pos-lim-sw-in
# AXIS Z
setp hm2_5i20.0.stepgen.01.dirsetup [AXIS_2]DIRSETUP
setp hm2_5i20.0.stepgen.01.dirhold [AXIS_2]DIRHOLD
setp hm2_5i20.0.stepgen.01.steplen [AXIS_2]STEPLEN
setp hm2_5i20.0.stepgen.01.stepspace [AXIS_2]STEPSPACE
setp hm2_5i20.0.stepgen.01.position-scale [AXIS_2]SCALE
setp hm2_5i20.0.stepgen.01.maxaccel 0
setp hm2_5i20.0.stepgen.01.maxvel 0
setp hm2_5i20.0.stepgen.01.step_type 0
net zpos-fb axis.2.motor-pos-fb <= hm2_5i20.0.stepgen.01.position-fb
net zpos-cmd axis.2.motor-pos-cmd => hm2_5i20.0.stepgen.01.position-cmd
net zenable axis.2.amp-enable-out => hm2_5i20.0.stepgen.01.enable
net all-home => axis.2.home-sw-in
net z-neg-limit => axis.2.neg-lim-sw-in
net z-pos-limit => axis.2.pos-lim-sw-in
# SPINDLE S
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd <= motion.spindle-speed-out
net spindle-enable <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
sets spindle-at-speed true
# connect miscellaneous signals
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---toolchange signals for custom tool changer---
net tool-number <= iocontrol.0.tool-prep-number
net tool-change-request <= iocontrol.0.tool-change
net tool-change-confirmed => iocontrol.0.tool-changed
net tool-prepare-request <= iocontrol.0.tool-prepare
net tool-prepare-confirmed => iocontrol.0.tool-prepared
This sounds a little similar to this:
www.cnczone.com/forums/emc_linux_enhance...xis_not_working.html
