Classicladder turret change help
21 Sep 2012 17:00 #24527 by jlviloria
Watch this video I found on youtube, so should move my turret.
please give me some other tips, to see if I can.
thanks.
23 Sep 2012 23:16 #24567 by andypugh
jlviloria wrote:
in liks you posted this information, but do not understand how to assign a code G, to a valve
If in the HAL you had
net valve_1 motion.digital-out-00 => hm2_5i25.0.digital-out-00
Then a G-code line of M64 P0 would turn on the output pin to drive the valve, and M65 P0 would turn it off again.
24 Sep 2012 17:14 #24585 by BigJohnT
jorge,
I have started a tutorial on Classicladder, it is in the beginning stages but might help a tiny bit.
06 Oct 2012 04:17 - 06 Oct 2012 04:25 #25052 by nkp
John, please tell me whether you can use two (or more) files classicladder(clp) simultaneously
for example:
loadusr classicladder --modmaster pur2.clp
loadusr classicladder1 custom.clp
Last edit: 06 Oct 2012 04:25 by nkp.
06 Oct 2012 10:34 #25054 by BigJohnT
What happened when you tried?
06 Oct 2012 14:02 #25061 by nkp
I was misled that only loaded one window GUI classicladder
Now understand: everything is good,
pins works of both files :)
06 Oct 2012 14:41 - 06 Oct 2012 14:42 #25063 by bigalex
Is it possible to run more than one instance of ClassicLadder ?
I understood that if you want to split the PLC program you have to use the multiple "section" into a ClassicLadder file.
What is the best practice ?
bigalex :blink:
Last edit: 06 Oct 2012 14:42 by bigalex.
06 Oct 2012 14:53 #25065 by nkp
Perhaps this is the only possible solution.
06 Oct 2012 17:35 #25069 by LAIR82
Hey Guys,
Hopefuly this were I can start to "pay it forward", is your turret functioning as you would like yet or no?
Reason I ask is 2 things, one, I got a little lost reading through this thread, and two, I have my turret functioning as required on my cincinnatti milacron 10CC project (except for the turret jog pushbutton), and I can post my ladder files monday when I get into the shop. It is a 7 position 14 tool turret, ( each position has an OD tool and an ID tool on it) and I did it completely through ladder using the IO control pins provided for the tool change.
Let me know if this could be of any assistance.
Rick
07 Oct 2012 03:05 #25089 by jlviloria
Hi Rick.
It would be wonderful you shared your experience with me. Look had no experience or knowledge of linuxcnc, but I swear it's the best thing that happened to me professionally. I learned a lot without even having done my project completed.
I would like to ask if your turret also has hydraulic motor, and also clarify how you can set the turret identify what position?
Any help would be great.
As data, I document everything and then post my experience with this project.
thanks
Jorge.
Time to create page: 0.133 seconds
