Compare expressions in Classic Ladder?
27 Dec 2012 04:26 #28060
by machete
Compare expressions in Classic Ladder? was created by machete
Hello, i'm trying to make two comparisons in one expression:
For example:
(%IF11=205)&(%W10=1)
((%IF11=205)&(%W10=1))
But Classic Ladder says Missing Parenthesis..
%IF11=205&%W10=1 - is not working
What is wrong with my expression?
P.S. Or is it possible to add extra columns in rungs (by default its only 10)?
(now i just cant perform 3 comparisons and 1 assignment in one rung)
For example:
27 Dec 2012 04:51 - 27 Dec 2012 04:54 #28061
by BigJohnT
Replied by BigJohnT on topic Compare expressions in Classic Ladder?
If you want to "and" two comparisons just create two on the same line...
--[%W11=205]----[%W10=1]--
Logic words like IF are not part of classicladder.
Last edit: 27 Dec 2012 04:54 by BigJohnT.
27 Dec 2012 07:15 - 27 Dec 2012 07:15 #28067
by machete
Sure, but i need 3 of them + 1 assignment in one line:
--[PHASE=1]----[Y-COORD=205]----[SP-SPEED=0]----[PHASE=2]--
But in 10 columns i can set only 3 of them in one line.
Replied by machete on topic Compare expressions in Classic Ladder?
Last edit: 27 Dec 2012 07:15 by machete.
27 Dec 2012 07:20 - 27 Dec 2012 07:21 #28068
by BigJohnT
Use the vertical connect tool, that should work.
--[stuff]--|
| --[more stuff]---
Or break it up over two rungs...
--[stuff]--|
| --[more stuff]---
Last edit: 27 Dec 2012 07:21 by BigJohnT.
28 Dec 2012 22:38 - 28 Dec 2012 22:46 #28122
by machete
OK, i brake it on two rungs.
But now i have to use modulus (to find shortest direction of rotation).
Integrator Manual V2.5
30.6.6 COMPARE
"ˆ (exponent),% (modulus),& (and),| (or),. -"
But how can i use modulus?
I tried, but it's all not working:
%(%IW11-%IW10)<=10 "Unknown term"
(%(%IW11-%IW10))<=10 "Missing Parenthesis"
(%IW11-%IW10)%<=10 "Unknown term"
((%IW11-%IW10)%)<=10 "Unknown term"
30.6.6 COMPARE
Last edit: 28 Dec 2012 22:46 by machete.
28 Dec 2012 22:45 - 28 Dec 2012 22:54 #28123
by machete
Last edit: 28 Dec 2012 22:54 by machete.
28 Dec 2012 23:53 - 29 Dec 2012 00:00 #28125
by BigJohnT
That is a classic example of the "last one wins" rule for PLC's. Read the
opening paragraph
for Classicladder.
Also the second comparison on the first line will always evaluate to true with the rung wrapped around it.
Last edit: 29 Dec 2012 00:00 by BigJohnT.
29 Dec 2012 05:34 #28136
by machete
And wat about modulus?
30.6.6 COMPARE
what is wrong in my expression?
30.6.6 COMPARE
29 Dec 2012 06:29 #28139
by BigJohnT
Dunno, I can't get modulus or power to work... if I find out something I'll holler.
30 Dec 2012 00:40 - 30 Dec 2012 00:41 #28159
by machete
This is very strange.
Without modulus i have to "scratch my left ear by right heel"...
Maybe this is a bug? (also with "and")?
Last edit: 30 Dec 2012 00:41 by machete.
Time to create page: 0.186 seconds
