Classic Ladder real time support with rtlinux
31 Jul 2013 15:41 - 31 Jul 2013 15:58 #37285
by nichis
Classic Ladder real time support with rtlinux was created by nichis
I would like to use Classi Ladder-0.9.008 with rtlinux. I use Ubuntu 10.04, and I'm following the readme file for the realtime support, but it doesn't work; when i writeI receive error like:
why is missing mbuff.h? It's not normal?.. I installed the rtlinux kernel using this link: askubuntu.com/questions/60405/can-i-install-rtlinux and it seems to work
what's the problem? is still working the realtime support for classig ladder or not?
edit:
if I correct manually that errors, namely i paste the mbuff.h into "include" folder, and correct ‘StrCounters’ with ‘StrCounter’, and ‘NBR_SYMBOL’ with ‘NBR_SYMBOLS’, and do againit goes but in the end i receive a segmentation error:
I think that realtime support for Classic Ladder is full of bug, isn't it?
make rtl_support
arrays.c:70:40: error: /usr/rtlinux/include/mbuff.h: File o directory non esistente
arrays.c: In function ‘ClassicLadder_AllocAll’:
arrays.c:382: warning: implicit declaration of function ‘mbuff_alloc’
arrays.c:393: warning: implicit declaration of function ‘CopySizesInfosFromModuleParams’
arrays.c:415: error: ‘StrCounters’ undeclared (first use in this function)
arrays.c:415: error: (Each undeclared identifier is reported only once
arrays.c:415: error: for each function it appears in.)
arrays.c:465: error: ‘NBR_SYMBOL’ undeclared (first use in this function)
arrays.c: In function ‘ClassicLadder_FreeAll’:
arrays.c:547: warning: implicit declaration of function ‘mbuff_free’
make: *** [arrays_.o] Errore 1
edit:
make rtl_support
drawing_sequential.c: In function ‘DrawSeqTransition’:
drawing_sequential.c:249: internal compiler error: Errore di segmentazione
Please submit a full bug report,
with preprocessed source if appropriate.
See <file:///usr/share/doc/gcc-4.4/README.Bugs> for instructions.
make: *** [drawing_sequential.o] Errore 1
Last edit: 31 Jul 2013 15:58 by nichis.
31 Jul 2013 17:05 #37287
by ArcEye
Replied by ArcEye on topic Classic Ladder real time support with rtlinux
Hi
Not sure why you are asking us this.
If you want to use classicladder with the rtai kernel, magma based realtime, as provided with Linuxcnc, there is a wiki here to get started
www.linuxcnc.org/docs/html/ladder/classic_ladder_fr.html
Otherwise you need to ask the rtlinux project why it does not compile
www.rtlinux.org
www.rtlinux.org
31 Jul 2013 17:43 #37289
by nichis
Replied by nichis on topic Classic Ladder real time support with rtlinux
yes thanks, I'm downloading it now.. I hadn't seen it before
Time to create page: 0.111 seconds
