Tool change problems - Help
10 Sep 2013 08:08 #38584
by DaOne
Tool change problems - Help was created by DaOne
Maybe someone could look at my hal / classic ladder and tell me why I cant seem to get a tool change complete back from classic ladder? Gotta be something simple. I also notice that not all relays reset every time. Maybe something I need to do differently? Here is my code. This is a hydraulic turret changer.
10 Sep 2013 21:39 - 10 Sep 2013 21:43 #38622
by BigJohnT
Replied by BigJohnT on topic Tool change problems - Help
It's not good practice to use the same output more than once. I see TUnclamp7 3 times and 2 are Resets.
Take a look at my ladder for my Hardinge here:
gnipsel.com/shop/hardinge/hardinge.xhtml
It's better to use latching rungs to control logic flow.
I find it helps to first write out the sequence of events in plain words then translate that to ladder.
JT
JT
Last edit: 10 Sep 2013 21:43 by BigJohnT.
10 Sep 2013 22:40 #38626
by DaOne
Replied by DaOne on topic Tool change problems - Help
Thanks JT,
One thing I can not figure out is even if I do a straight through call from toolchange request to tool change complete in the first rung I still don't seam to get a toolchange complete. The toolchange request contact is still help on. Any idea why? I got lots to learn on this still and I am slowly figuring things out as I go. Thank you for your help.
11 Sep 2013 00:10 #38633
by BigJohnT
I thought I was losing my mind but I found it and the Classicladder examples as well... there is a turret example that runs as a sim so you can watch the rungs as you toggle the inputs.
gnipsel.com/linuxcnc/ladder/index.html
JT
JT
12 Sep 2013 10:33 #38681
by DaOne
Works!
Tell me what you think of the new code?
12 Sep 2013 17:44 #38690
by BigJohnT
I assume you mean HSLathe.clp? It looks very familiar to me. The main thing it that you got it to work.
JT
JT
Time to create page: 0.069 seconds
