How to assign hal pins to %I and %Q in classicl.
17 Nov 2013 23:07 #40896
by zek99
How to assign hal pins to %I and %Q in classicl. was created by zek99
First attempt with classicladder and linuxcnc. Only programmed Fanuc ladder with faptladder earlier.
I have a general mechatronics pci-card running. In the gm.hal file i have started classicladder with:
loadrt classicladder_rt
loadusr classicladder
addf classicladder.0.refresh servo-thread
In the halmeter I can see all the signals from the gm card for example the emergency stop signal gm.0.estop.0-in.
How do I assign the gm.0.estop.0-in signal to a classicladder input signal for example %I0? If I try to write it in the symbols list classicladder only erase it and replace it with "No hal signal connected".
18 Nov 2013 00:14 #40901
by BigJohnT
Replied by BigJohnT on topic How to assign hal pins to %I and %Q in classicl.
You have to connect I/O in your hal file to the real world.
Please read this: www.linuxcnc.org/docs/html/hal/basic_hal.html
JT
net my-name pin-1 pin-2
JT
18 Nov 2013 03:53 #40908
by zek99
Replied by zek99 on topic How to assign hal pins to %I and %Q in classicl.
Thank's a lot BigJohnT. I read all classicladder forum post and discovered that.
But when testing that I realize that if I made a couple of rungs, save them, quit linuxcnc and then restart no rungs shows up if I open the classicladder. If I edit the clp-file directly all my rungs are there. Hmm strange. I could edit directly into the clp-file but then you miss the point with having a ladder diagram for visibility.
I will have to connect some switches and LED's to whats working and what's not.
18 Nov 2013 04:20 #40909
Replied by cmorley on topic How to assign hal pins to %I and %Q in classicl.
Try save-as instead of save. I think save is broken.
Also you must specify the ladder program name when you load it.
loadusr classicladder myladder.clp
else it doesn't load any program.
Chris M
Chris M
18 Nov 2013 05:50 #40910
by zek99
First I thought it was because I'm running 2.6.0 but same problem in 2.5.0.
Then I suspect ownership of the hal-file or problem with the searchpath but no.
Finally, finally I discover that the whole problem was due to me ending the filename with cpl instead of clp. Gaaaaah!!
Good night friends.
Good night friends.
Time to create page: 0.117 seconds
