variable comparison problem
23 Nov 2015 13:32 #65698
by viski
variable comparison problem was created by viski
Logic i have to compare to be output true !
If (%IW1-%IW0)>0&<5 | <-6 then TRUE
if (%IW1-%IW0) <0&>=5 | >=-6 then TRUE
How to wrote this into COMPARE block ?
24 Nov 2015 04:57 - 24 Nov 2015 04:58 #65727
Replied by cmorley on topic variable comparison problem
break it up a bit should work.
I think this is the logic you want:
(%IW1-%IW0)>0 ---+----%IW1-%IW0)<5--------+--------output
L-------%IW1-%IW0)<-6----J
Last edit: 24 Nov 2015 04:58 by cmorley.
Time to create page: 0.299 seconds
