Not seeing s32in value in classicladder
22 Feb 2016 17:54 - 22 Feb 2016 17:55 #70488
by djs14
Not seeing s32in value in classicladder was created by djs14
Hey all,
I'm fooling around with classicladder trying to get a tool changer system working.
Right now I have created a pyvcp scale box to simulate tool number selection.
I have mapped the halpin with the -i designation to halpin tool-request, and then in my main hal file I map the tool-request halpin to s32in-05 of classicladder, but when viewing variables in classicladder I'm not seeing this variable change.
Thoughts?
Thank you
Thoughts?
Thank you
Last edit: 22 Feb 2016 17:55 by djs14.
22 Feb 2016 19:26 #70490
by djs14
Replied by djs14 on topic Not seeing s32in value in classicladder
I've got my value printing back to a S32 number box with a pyvcp, but I can't get the value into classicladder.
Easy one for you guys ... come on.
cheers
cheers
- Thank you received: 1369
22 Feb 2016 20:13 #70491
Replied by Todd Zuercher on topic Not seeing s32in value in classicladder
Lets start with the basics are you sure that your pyvcp.my-hvalue-i is an S32 output? Since you didn't include your pyvcp files we can only guess.
Where are you looking for your value in Classicladder? The Classicladder S32 input you have connected to the HAL signal "tool-request" will show up as variable %IW5 in CL. I don't see that variable mentioned in the custom.clp you attached.
The following user(s) said Thank You: djs14
22 Feb 2016 20:40 - 22 Feb 2016 20:45 #70493
by djs14
Thank you brother!
I did not realize the variables would be %IW5 vs just %W5. Changed that in my variable monitoring and I got it for now. I've added my xml file that has the pyvcp declarations. I think that is legit for now. Sorry for my messy programming. I'm just getting my head around all the very powerful features of this system. I think with this info I can get my tool changer working.
Thanks again.
cheers!
Thank you brother!
Thanks again.
cheers!
Last edit: 22 Feb 2016 20:45 by djs14.
Time to create page: 0.135 seconds
