Monostables stop working?
06 Jul 2016 16:52 #77092
by jeeybee
Monostables stop working? was created by jeeybee
I control a toolchanger with classicladder and it worked fine until today when I added a couple of more rungs and now it changes tool perfectly the first one or two times and then the monostables seem to stop sendin the signal thorough, it just stop before it?
Have I exeded some limit or could there be somthing other that causes it?
I have 19 signals in and 15 out in 13 rungs.
06 Jul 2016 17:02 #77093
by jeeybee
Replied by jeeybee on topic Monostables stop working?
If I pres Stop and Run in classic ladder to restart the program it does not help, but if I press reset to reset all the values then I can do another toolchange and after that the monostables are not working anymore.
06 Jul 2016 20:19 - 06 Jul 2016 20:23 #77104
Replied by andypugh on topic Monostables stop working?
Someone on IRC suggested:
" breaking when he added things makes me wonder if he has numThis and numThat set right: www.linuxcnc.org/docs/html/ladder/classi...tml#_realtime_module"
Last edit: 06 Jul 2016 20:23 by andypugh.
- skunkworks
- Thank you received: 148
07 Jul 2016 01:45 #77122
by skunkworks
Replied by skunkworks on topic Monostables stop working?
I agree with Andy. if you don't have enough allocated - things start to act goofy.
07 Jul 2016 08:00 #77130
by jeeybee
Thanks for the tips but it was the servo period that was the problem, at 1250000 (real time kernel) it work but if I raise it to 1400000, then the problem with classic ladder occurs.
But why?
But why?
07 Jul 2016 17:06 #77147
by jeeybee
I guess its because it does not have time to do what it has to do before the next period starts, am I right?
But why?
07 Jul 2016 17:18 #77148
That would make sense if shortening the period caused a problem, but you seem to be saying that lengthening it was the problem.
But, why 1,250,000nS anyway? The normal default is 1,000,000.
07 Jul 2016 17:22 #77149
by jeeybee
I get latency problems when I set it lower.
07 Jul 2016 17:57 #77151
It might be that your PC is sub-optimally configured then. Or simply just unsuitable. What does the latency test show?
07 Jul 2016 18:36 #77155
by jeeybee
Yes well I had a really hard time to get it to work with the 7i80 and real time kernel, I got alot of help with that in another thread, partly from you I think
At 1250000 it works fine but I get the latency error once in a while but it does not seem to affect anything, is it possible to turn it off?
Time to create page: 0.325 seconds
