Axis error 0 following error
29 May 2016 01:57 #75207
by Air Chunk
Axis error 0 following error was created by Air Chunk
Hello,
I have a new to me (used) Daewoo Puma 10 cnc lathe that has the linux cnc on it.
I ran the x axis to the soft limit stop and could not get it to come off of the stop.
(unlike my milling machine that has the linux on it also)
The guy before me retrofitted it linux.
So to override the limit switch there is a toggle switch. that you have to hold down with your hand to get it off of the stops.
Well , it did not work.
SO I manually cranked it off of the stop , Now all I get is an error code
Axis 0 following error.
I am not sure what to check.
Any help is appreciated.
Thank You!
Thank You!
04 Jun 2016 22:18 #75506
by jstoquica
Replied by jstoquica on topic Axis error 0 following error
It´s a common bug, I thing you have to modify your INI file. you can visit this site:
wiki.linuxcnc.org/cgi-bin/wiki.pl?Following_Error
Regards.
Regards.
07 Jun 2016 10:23 #75617
It sounds like the servo amp might still be disabled.
"Axis.0.following error" means that the X axis (cross-slide) is not moving to where the system is trying to move it to.
Specifically, if you look in HAL (you can use halmeter, or halshow (Machine-Show HAL config in the Axis GUI) to see the values active in HAL. You will see that axis.0.motor-position-cmd and axis.0.motor-position-fb are not the same number.
You should see the motor-position-fb pin change when you move the axis manually. If not then something is wrong with the encoder.
Replied by andypugh on topic Axis error 0 following error
26 Jul 2016 04:33 #78030
by vre
Replied by vre on topic Axis error 0 following error
How is an acceptable ferror & min_ferror for a lathe in mm ?
27 Jul 2016 14:46 #78074
I think that is up to you to decide.
Moderators: piasdom
Time to create page: 0.092 seconds
