Lathe threading with single phase encoder?
- HalaszAttila
- Thank you received: 5
28 Feb 2017 10:44 #88722
by HalaszAttila
Lathe threading with single phase encoder? was created by HalaszAttila
Hello,
we retrofit an Emco 220 lathe with Linuxcnc + 7i76 card.
The encoder on the spindle has just one phase (not quadrature) 100ppr, with index signal.
My question is, that can I use this encoder for threading or not?
For threading method, important for Linuxcnc to know the direction of spindle?
01 Mar 2017 12:50 #88803
Replied by andypugh on topic Lathe threading with single phase encoder?
100 pulses + index is more than adequate for lathe threading.
It can't be used for rigid tapping.
You just need to set the encoder to "counter mode" so that it will count without a B phase.
29 Mar 2017 22:22 #90529
by MAG45
Replied by MAG45 on topic Lathe threading with single phase encoder?
Dont mean to hijack, but im trying to find what I need to turn threads using LinuxCNC and stepper feeds on my lathe. Is it just a matter of adding a 1ppr sensor and sensor disk on my spindle? How is it set up in linux?
would this type sensor work, or what would i need? www.ebay.com/itm/1x-Slotted-Optical-Swit...f:g:W-QAAOSwyZ5Ungn9
Moderators: piasdom
Time to create page: 0.231 seconds
