G76 Threading cycle code location want to cut taper thread
- massimodamassa
- Thank you received: 9
10 Jul 2017 05:51 #95578
by massimodamassa
Replied by massimodamassa on topic G76 Threading cycle code location want to cut taper thread
If G70,71,72 would work, it would be possible to use the turning simply by describing the profile without using a cam, it should be a sequence of G0 and G1 where it takes into account the depth of the past starting from the difference between the starting profile and the final one .
Great job you did with the G76, congratulations
The following user(s) said Thank You: snujcnc
10 Jul 2017 09:03 #95583
by snujcnc
Replied by snujcnc on topic G76 Threading cycle code location want to cut taper thread
but now g71 g72 is not working and i want to use g71 and g72 like other system offers
do you have any ready solution for linuxcnc ?
- massimodamassa
10 Jul 2017 11:15 - 10 Jul 2017 11:20 #95587
by massimodamassa
Last edit: 10 Jul 2017 11:20 by massimodamassa.
10 Jul 2017 12:34 #95595
It is on the way.
Currently built-in TypeI G71 and G72 exist in a feature branch:
github.com/LinuxCNC/linuxcnc/tree/BenPotter/G71
And there is a TypeII setup achived via a python remap here:
github.com/LinuxCNC/linuxcnc/tree/andypugh/g71type2remap
It should be possible to add the latter to any current config.
The plan is to use the remap to test the algorithm and then re-code it into a built-in cycle.
Replied by andypugh on topic G76 Threading cycle code location want to cut taper thread
It is on the way.
The following user(s) said Thank You: snujcnc, massimodamassa
Moderators: piasdom
