- Hardware & Machines
- Turning
- Problems with the Boxford240 toolchanger component on Emco Compact 5 CNC
18 Sep 2017 17:54 #99093
by javanree
I'm slowly converting an Emco 5 CNC to LinuxCNC, replacing all the electronics.
For now it's a cheap LPT board, 3 DM542 steppers and a cheap Atom board driving it, LinuxCNC 2.7.11
Finally I've been able to get it to run as it should, even getting the toolchanger module to work. Sorta...
First of all there appears to be a long delay after a forward rotate, before it does the backwards rotate against the pawl. It feels like 2-3 seconds. But I can't find this pause anywhere in the code?
Second, the change works as long as I don't move more than 3 steps, but if I do like M6T6 while T2 was active the turret will try to spin backwards
I've modified the toolchanger.comp code, replacing all the references of 8 positions to only 6 and both the even and uneven steps are declared as 31.0 degrees. I've also had to set fudge factor to 2 to get it to lock properly.
The modified file is attached, I'd appreciate any pointers.
22 Sep 2017 02:19 #99232
Replied by andypugh on topic Problems with the Boxford240 toolchanger component on Emco Compact 5 CNC
I find it quite hard to follow other people's code, but I think that there might be a max 7000 servo cycles delay in:
That would be 7 seconds.
if(position_req >= 70)
delay = 70;
else
delay = position_req;
25 Sep 2017 08:03 #99394
by javanree
Replied by javanree on topic Problems with the Boxford240 toolchanger component on Emco Compact 5 CNC
Thanks for looking into it.
Unfortunately the same delay is used several times in the code, so if I change it other things no longer work.
All in all, for my use I will need to rewrite it and in the meantime learn to live with the limits of the current component.
27 Sep 2017 06:25 #99505
by javanree
For now I managed to solve the most urgent issue (turret going wrong way on large moves) by changing the scale of the rotating axis in the INI file and by dividing the angle again by two in the toolchanger.comp file (so for my Emco which has tool mounts every 60 degrees I now have a move_odd and move_even of 15.5 degrees)
Moderators: piasdom
- Turning
Time to create page: 0.253 seconds
