Need help setting up a lathe(Sherline)
16 Nov 2019 04:58 #150451
by kbec
Need help setting up a lathe(Sherline) was created by kbec
I am planning on controlling a Sherline lathe with Linux CNC. I will be using the Sherline Nema 23 motors, and I have a computer. What else do I need? I see Sherline has a '4 axis driver box', but I think that is expensive.
Unless I am missing something, I only need 2 axis, but I am not really seeing much labeled as such, lots of 3 and 4.
I also see driver boards, breakout boards and power supplies, I am not sure which of these I need.
I am thinking I can just initially set up the motors to whatever to play with Linux CNC and when I get everything working connect them into the lathe.
16 Nov 2019 08:05 #150458
by pl7i92
Replied by pl7i92 on topic Need help setting up a lathe(Sherline)
Hi
you can go very low Cost
What budget do you got or expect
4th Axis is a standard board
in modern times a Ethernet woudt be best
there are a 7i92 Interface that fits the sherline
but with a PCI parport card at 20USD is also a good respons
do you need to build the box or is the sherline box alredy installed
16 Nov 2019 10:55 #150465
by Leon82
Replied by Leon82 on topic Need help setting up a lathe(Sherline)
You would need
Breakout card(there are some on eBay for as low as 6 dollars)
2 stepper drives(1 for each axis)
2 steppers
1 switching power supply( will support 3 drives some are adjustable for voltage)
Some 18-22 gauge wire.i used 18 for power and motor wires and 22 for limit switch.
Motor mounts,
Sherline has a couple CNC kits, I think they have one with just adapters for bolting up the steppers.
Also if the PC doesn't have a parallel port will need a paraport card, and cable.
2 steppers
Motor mounts,
16 Nov 2019 17:01 #150481
by kbec
Replied by kbec on topic Need help setting up a lathe(Sherline)
I have only ordered the steppers at the moment, and have a computer to use for it.
I am trying to figure out what else I need. I am overwhelmed as it seems there are a bunch of configurations and they are all different. If the 7i92 Interface is a good option, I'd hopefully be able to use the ethernet port. What else would I need? I am guessing a power supply, but don't know about driver boards or a breakout board.
16 Nov 2019 17:31 - 16 Nov 2019 17:42 #150482
by Leon82
I have this one(one like it )
rover.ebay.com/rover/0/0/0?mpre=https%3A...2Fitm%2F282099594144
A Chinese power supply from Amazon
You could probably use a lower voltage one a little less expensive
MYSWEETY Adjustable DC Power Voltage Converter AC 110V-220V to DC 0-60V Module 60V 8A Switching Power Supply Digital Display 480W Voltage Regulator Transformer Built in Cooling Fan www.amazon.com/dp/B07HGQXW9V/ref=cm_sw_r_cp_apa_i_Hid0DbYCE88CM
One drive option
www.automationtechnologiesinc.com/produc...pper-drivers/kl5056/
One drive option
Last edit: 16 Nov 2019 17:42 by Leon82.
17 Nov 2019 08:51 #150511
by pl7i92
if you are on budget high
use the 7i96 it brings all the needed direct connect
while the 7i92 is always a double component option and has the most side tricks to go on further mashine action
BUT you can go for the First and low cost setup on standard components
WHAT steppers did you order
and why dident you consider the 2Nm Hybrid in first place very tiny high speed and best precision
17 Nov 2019 14:30 #150523
by kbec
I have these, www.sherline.com/product/67127-stepper-motor/#specifications
I wanted those since I know the dimensions would work and other have used them while manually using the machine as well.
The following user(s) said Thank You: Mike_Eitel
17 Nov 2019 15:20 #150524
by pl7i92
manually using the mashine while steppers/DYNAMOS are connected is quite a chellenge for the Drivers
Analog drivers like D542 may produce 150V towards the electronic while turning the Spindel manually
be aware of that you can get nice quick connects between them it is nor a good work but safe
and you will fast realy fast find out you mashine no longer needs manuell as of subs on the controll will get you fast into conture
17 Nov 2019 18:10 #150531
by kbec
I know I would need to disconnect them to do any manual work. I just want the option in case I need it. I am just starting out.
17 Nov 2019 19:52 #150539
by Leon82
Do they sell the female side of that connection? It would make wiring it easier.
Moderators: piasdom
Time to create page: 0.105 seconds
