7i43 connect error
28 Jun 2011 19:16 #10930
by cncbasher
7i43 connect error was created by cncbasher
i have a 7i43-4 , that appears to not respond , or possible other problem , so has anyone come across any problems ?
it appears at first glance to be able to communicate with the pc as it responds that the chip is a spartan c200 and not as it is a 400 version .
but this could be a fallback situation when infact no communication is in place , so is their a way to check or re-initialise the 7i43 to default
just in case some other configuration has screwed it .
any guidance pointers ?
i could connect the jtag port i presume , but is their any easier faultfinding procedures with them .
Dave
Dave
28 Jun 2011 20:07 #10931
Replied by PCW on topic Re:7i43 connect error
Is this a card that was working or is this a first time setup?
28 Jun 2011 21:02 - 28 Jun 2011 21:05 #10932
by cncbasher
Replied by cncbasher on topic Re:7i43 connect error
hi first time setup , although it may have been connected up on usb on windows , but quite a few months ago
Last edit: 28 Jun 2011 21:05 by cncbasher.
28 Jun 2011 22:37 #10936
OK for first time EPP setup a couple of things to check:
1. Card is jumpered for EPP and host downloaded config (W4 and W5 down)
2. Card has power (2 red LEDs and the yellow LED should be on before the configuration is loaded)
3. You have a working EPP port set in EPP mode (in BIOs setup if port is on motherboard)
4. EPP cable is correct
29 Jun 2011 13:05 #10950
by cncbasher
ok found the error the printer port was set to ECP & EPP mode , changing to EPP only solved the problem
Time to create page: 0.071 seconds
