Using velocity amps with no motor tachs
25 Nov 2009 16:33 #1196
by Dave_Dyke
Using velocity amps with no motor tachs was created by Dave_Dyke
I am retrofitting a mill to emc2, the old control is a 3 axis fanuc 6M which uses velocity amps, although the servo motors do not have tachs.
Is it possible for emc2 to send a tach signal to the amps (6v/1000rpm).
I currently plan to use a mesa m5i20 and two 7i33 cards, so that gives me DACs for XYZA & spindle, so I have 3 DACs available to use for an analog velocity signal for the fanuc amps.
If this is not possible, is there another way to generate velocity signals from the encoder signals.
Thanks for any advice.
Dave
Dave
26 Nov 2009 03:10 #1200
Replied by PCW on topic Re:Using velocity amps with no motor tachs
Well maybe...
I guess you could connect the encoder velocity signal from the HM2 encoder modules to the spare DAC channels in HAL
Here are some possible bumps going down that road:
1. Velocity feedback needs to be fast so you may need a higher than normal servo thread rate (maybe 2 or 4 KHz) for stability
2. There was a recently fixed bug in HM2s velocity estimation so you would need the development version of EMC to get a good velocity signal
(the release version has big velocity glitches on reversals)
3. The 7I33s only output +- 10V so you would be limited to ~1600 RPM (and the servos would lose velocity control and probably fault-out
if asked to run faster than ~1600 RPM)
4. Whether the velocity estimation is good enough to replace a tachometer is unknown
Sounds like a fun experiment. I would definitely try this with bare motors, expecting runaways.
29 Jan 2010 10:44 #1685
by semis
Replied by semis on topic Re:Using velocity amps with no motor tachs
Hi Dave
I could offer two chanel encoder to tacho-signal converter, which ditributes the encoder signal to the CNC system.
Best regards
Radoslav
Best regards
Radoslav
29 Jan 2010 16:00 #1689
by Dave_Dyke
Replied by Dave_Dyke on topic Re:Using velocity amps with no motor tachs
Radoslav,
I would be interested in such a converter, can you give me some details.
I've not yet started this project, so having some options now will be good.
Dave
Dave
30 Jan 2010 14:58 #1696
by semis
Dave
Contact me at: This email address is being protected from spambots. You need JavaScript enabled to view it. to send you the Manual
Best regards
Radoslav
Best regards
Radoslav
