Using only parallel ports ?
- garymcrobertpdx
27 Nov 2009 16:47 #1212
by garymcrobertpdx
Using only parallel ports ? was created by garymcrobertpdx
Is it practical to attempt configuring a 6 axis machine using
only parallel ports (2 or 3 boards) for step motor and encoder
IO or should I invest in a more specialized support board
in order to get acceptable performance. The latency of my
PC is about 20,000 ns
02 Dec 2009 04:10 #1228
by BMG
Replied by BMG on topic Re:Using only parallel ports ?
There is a recent discussion in the email lists on the limitations of software encoder counting (you can search the archives for details). If you dealing with a home hobby machine, you may be able to live with the speed limitations of the parrallel ports. If this is for production, why short yourself. You might investigate the Mesa or Pico products and costs first before considering further. the price may not be all that bad for you.
Time to create page: 0.070 seconds
