issues with cio dio24h board
17 Aug 2011 23:14 - 17 Aug 2011 23:15 #12565
Replied by andypugh on topic Re:issues with cio dio24h board
I wonder if it is funky line-endings from the forum?
I have attached the current version of the driver (which I pushed to the main branch a few days ago, so I hope it works)
Last edit: 17 Aug 2011 23:15 by andypugh.
17 Aug 2011 23:16 #12566
by patburden
Replied by patburden on topic Re:issues with cio dio24h board
BigJohnT wrote:
I will read thru all this and give it a try
I read in another thread that I should add it to my Hal file
I haven't quite figured that out yet but I am still reading and making progress
Thanks for the help.
Can you copy one of the example comps from the manual to a directory and get that to compile?
www.linuxcnc.org/docview/html/hal_comp.html
17 Aug 2011 23:22 #12567
by BigJohnT
Replied by BigJohnT on topic Re:issues with cio dio24h board
You do have to get it to compile first then add it to your HAL file.
Just do a simple one from the manual and get the compile part down then do the one Andy added.
18 Aug 2011 22:40 - 18 Aug 2011 22:49 #12603
by patburden
Ok I did all the examples - "rand.comp" ran fine all others except "out8.comp" gave warnings - undefined
"out8.comp" gave warnings and errors.
I then ran the one Andy posted. and I got this
/Desktop$ sudo comp --install pcl720.comp
make -C /usr/src/linux-headers-2.6.24-16-rtai SUBDIRS=`pwd` CC=gcc V=0 -o /Module.symvers modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.24-16-rtai'
CC [M] /tmp/tmp_ICNMA/pcl720.o
pcl720.comp: In function ‘reset’:
pcl720.comp:93: warning: unused variable ‘deadline’
Building modules, stage 2.
MODPOST 1 modules
WARNING: "rtapi_delay" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "rtapi_get_time" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "hal_ready" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "hal_export_funct" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "hal_param_bit_newf" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "hal_param_u32_newf" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "hal_pin_u32_newf" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "hal_pin_bit_newf" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "rtapi_print" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "hal_malloc" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "rtapi_snprintf" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "hal_init" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
WARNING: "hal_exit" [/tmp/tmp_ICNMA/pcl720.ko] undefined!
CC /tmp/tmp_ICNMA/pcl720.mod.o
LD [M] /tmp/tmp_ICNMA/pcl720.ko
make[1]: Leaving directory `/usr/src/linux-headers-2.6.24-16-rtai'
cp pcl720.ko /usr/realtime-2.6.24-16-rtai/modules/emc2/
I read in another post that I can ignore these warnings.
I also ran this and got a list pin properties
halrun
loadrt pcl720 ioaddr=0x300
loadrt threads
addf pcl720.0.write thread1
start
show pin
show thread
show funct
So if I am understanding things right - this compiled and I am on to the next step
which is to add it to my hal file-
Thanks for all your help.
MODPOST 1 modules
halrun
loadrt threads
start
show pin
show thread
show funct
Last edit: 18 Aug 2011 22:49 by patburden.
18 Aug 2011 22:55 - 18 Aug 2011 22:56 #12604
by BigJohnT
patburden wrote:
Yep, you made it
If you add it in small chunks and test that it loads after each addition you can be sure you didn't slip in a typo or some other mistake. This make troubleshooting much easier.
Yep, you made it
Last edit: 18 Aug 2011 22:56 by BigJohnT.
Time to create page: 0.083 seconds
