Mesa AnythingIO and daughter card capabilities q.
18 Feb 2010 01:58 #1952
by clytle374
Replied by clytle374 on topic Re:Mesa AnythingIO and daughter card capabilities q.
PCW wrote:
Great, thanks a bunch.
Now to do the "hurry up and wait" routine with the UPS man, while doing some schematics.
Jeplers patch worked first time. I had to make a small revision in the VHDL so the enables work as before
(7I48 has common enable for all 6 outputs, not one per channel like 7I33)
HAL file needs some tweaks as well (PWM mode set to 2 mainly)
24 Feb 2010 00:24 #2023
by clytle374
Is this code going to be in the development version soon?
Cory
Cory
24 Feb 2010 04:11 #2026
Replied by PCW on topic Re:Mesa AnythingIO and daughter card capabilities
That I do not know... Maybe you could ask on the emc-devel irc channel
the patch was easy enough to apply but you need the emc source and devel tools
24 Feb 2010 05:27 #2028
by clytle374
PCW wrote:
I've got the source up and running already, I expected to have to build it.
I'll ask on the forums again tomorrow. One quick question. I accidentally ended up with Xilinx 11.1 do you know if this will work? If so what is the config.sh equivalent?
24 Feb 2010 05:27 - 24 Feb 2010 05:29 #2029
by clytle374
double post
Last edit: 24 Feb 2010 05:29 by clytle374.
Time to create page: 0.097 seconds
